nokia 5530 flashing complete local mode but power on problem (ANSWERED) hi i have one nokia 5530 i would like to explain in detail about set condition first the problem in set was only music player problem then i flashed with 40.0.003 firmware with same product code , flashing complete phone enter in localmode too but when want to power on by battery only vibrate then nothing now i m in confusion wats the problem i found the so many solution in forum but din't work for me i checked the bsi line it is showing continuty any body hav solution ? can any one tell me where is the problem in hardware or software |
bro. post full logs of buscheck & self test. you will get solution immediately. |
Sound like BSI line problem When you measure you press on the conector and make contact Open the phone, resolder/check carefully battery conector and bsi line |
bro. before full logs how you got solution of bsi as phone was working with music player problem before flashing. |
try to force pwr-on from soft, anyway need flashing log, maybe downgraded,or while flashing,broken connector... |
ok i hav attached here my logs MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085B5D6 Using device: USB ROM and HTI, FW ver: 00.50, SN: 000031F6 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.73 Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012) Processing MCU file: RM-504_40.0.003_prd.core.C00 [BB5,XSR 1.5] size: 100.23 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 0A40010A3C8800520B94279D16F66A4DB9A78E0A CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT ROM ID: 4B9B75103E691FF8 Flashing CMT Update Server Data, ULO: 0x3B80 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, XSR: 0x2627A5 bytes Update Server code succesfully sent to phone. Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2E0891A Verifying communication to device OK. Partitioning.... Partitioning complete Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: F2B05364 [RAP Certificate 168 v.1] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 59.688 s Processing PPM file: RM-504_40.0.003_prd.rofs2.V22 [BB5,XSR 1.5] size: 31.50 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 32 MB CMT FLASH,MuxOneNAND area [07360000-0935FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 19.515 s Processing CNT file: RM-504_40.0.003_C01_prd.rofs3.fpsx [BB5,XSR 1.5] size: 5.04 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 11 MB CMT FLASH,MuxOneNAND area [09360000-09E5FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 3.203 s Total time for flashing process(boot+erase+write) was 1 min 36.500 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 5530 XpressMusic USB Phonet, PORT_ID: A13FCCA Verifying communication to device OK. Phone type: RM-504 (Nokia 5530 XpressMusic) SW version: V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia ApeCoreSw: V 40.0.003 Imei plain: 35830703381324-4 Product code: 0573473 Battery voltage: 3702 mV, current: 243 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358307033813244 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN i am waiting for urs respond |
when u turn on the phone, do call (green) and no (red) button have lights on? try this bro: service> quick fix> tick on bb5 sw downgrade fix & bb5 rap3nand erase> click do selected jobs post selftest log, maybe lcd damaged is possible. good luck bro br |
two possibilities: - do rap3nand erase, still the same problem; - flash ENO MCU still same problem? check phone battery and BSI contact |
