Old 01-31-2012, 05:39   #1 (permalink)
Member: 421487
Thanks Meter: 58
need solution 3110 secoury test failed
1 sdrepair 2sd aut p3 pm from server but same problem pl check Using device: HTI, FW ver: 00.50, SN: 00012946
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 24400005D83A8B56CA0835925BFA4112E75052BF
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Original Imei: 35602903043979
Original Product code: 0581519
Bluetooth ID: 0025D04E12B2
Phone type: RM-237 (Nokia 3110c)
SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
Imei plain: 35602903043979-7
Battery voltage: 4687 mV, current: 90 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 356029030439797
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 01-31-2012, 05:52   #2 (permalink)
.::RanjitSinh::.'s Avatar
Member: 517102
Sonork: 100.1601229
Thanks Meter: 199
do pm auth with modified pm 1 & 309
Old 01-31-2012, 05:52   #3 (permalink)
jagdish puri's Avatar
Member: 573120
Thanks Meter: 145
http://forum.gsmhosting.com/vbb/f299...2/#post7474417
if not done by this steps then flash it with same product code .
Old 01-31-2012, 07:08   #4 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
use SEARCH button, then your problem will be solved. a lot of threads discussed it like forever...
learning by searching
br
Old 01-31-2012, 09:39   #5 (permalink)
msattar123's Avatar
Member: 645436
Thanks Meter: 1,501
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
TRY THIS 100% WORKED TESTED
Important-Backup RPL
1. super sd auth or pmm auth __than write good or modified pm ( must need pm 1 & 309)
or, 2. sd repair ___ super sd auth or pmm auth ____ than write good or modified pm ( must need pm 1 & 309)
when we not success by up system
than what can we do for repair security test failed?
Then
1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl)
2. erase old pm ( go > pm tab > erase )
3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this)
4. Erase pm again (go > pm tab > erase )
5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei)
6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309)
7. erase pm again
8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert)
9. give full factory reset
your phone must come back from security test failed
The Following User Says Thank You to msattar123 For This Useful Post:
Old 01-31-2012, 10:06   #6 (permalink)
Registered User
Member: 1669709
Sonork: 1654655
Thanks Meter: 163
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
no dnt erres ur mobile.
1. rapir sd
2.super sd auth
3. lod rfbb form sever and write pm
4, factry restor only
ur set wil ok. dnt forget thanx
Old 01-31-2012, 10:09   #7 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
@msattar123
100% perfect solution
Old 01-31-2012, 10:10   #8 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
Then
7. erase pm again
Old 01-31-2012, 10:14   #9 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Then
7. erase pm again
bro. no need to erase, only do pmm auth RF/BB, your problem will be solve.
Old 01-31-2012, 10:25   #10 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
I try everything but not success at last success by msattar123 given solution.
Old 01-31-2012, 12:52   #11 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
SEARCH button is the first option before asking and starting a new thread
u must have seen this if u SEARCH (posted 24-02-2011)
http://forum.gsmhosting.com/vbb/f550...ailed-1214364/
br
Old 01-31-2012, 12:58   #12 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
br
bro. he already done his job but by the way thanks for helping others.
Old 01-31-2012, 13:12   #13 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
i know bro, that's why i stated the date of the solution been posted
if he just want to search for more, he can find himself the solution, that's my point, no offense
br
The Following User Says Thank You to specta For This Useful Post:
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.37428 seconds with 9 queries
