NOKIA 5800d-1 RM-356 v30.0.011 NOT ABLE TO UNLOCK:(- NOKIA 5800d-1 RM-356 v30.0.011 NOT ABLE TO UNLOCK WITH MX-KEY:confused::confused: READED INFO Code: Version Info: Code: Imei: 356910038004750 CAN WE UNLOCK THIS VERSION WITH MX-KEY?? WBR sahil2000ind |
some with downgrade procedure, try in ver 2.x br, |
pl check here .(Error: Security block invalid or PM corrupted !) can use tool repeair pm files then unlock.good luck ! |
Version not supported.... Quote:
don't downgrade the phone, it will be dead.. br. |
downgrade,can't flash phone....not work.... |
I can be unlocked but is about an hour of work to unlock it and must be done with an exact sequence. BR Alex |
Belive me you can unlock with mx-key too.. just you must know the route. BR Alex |
please say how Quote:
please share with us you knowlage. tel us how to unlock 5800d-1 !! br adam92se |
You need a full PM back-up and an RPL from the phone. Downgrade it to V21.0.25 product code 0573738 use the function rebuild simlock from PM and select the PM back-up unlock the phone (save the unlocking code calculated) flash with erase file 5800_Erase_256MB_kashi4gul with skip ape enabled Flash with firmware E71 v300 product code 0559569 with "skip APE" enabled only COR and PPM Write back the PM 308 and 120 back-up Full flash again the mobile with the original firmware APE included Write back the RPL sx4 auth write back FULL PM no 308 no 120 start the phone Input the unlocking code via keyboard or via fbus. BR Alex |
i beleive it is more than 1 hours jobb Hi mate; I will give it a try and will let you know. In meanwhile, I hope MX-Key team will find out and implement their own solution. thanx Quote:
Imei: 353205037814157 Version: SIMLOCK SERVER Provider: Bouygues Telecom , Country: France Counter: 0/3, 0/10 CONFIG_DATA: 2082000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 20820F, DATA=20820F BLOCK 2: 1=LOCKED (MCC+MNC): 20820F, DATA=20820F Backup already exist. Using device: J.A.F, FW ver: 01.B1 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x190C bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1A20 bytes) ...OK Calculating NCK using security server ... Connecting to server[nkrpl.biz] ...OK, Login ... Sending NCK code ... Trying NCK lock 7 ... VER 21....025 UNLOCK NOT OK, PSL HELP |
5800d-1 V30.0.011 Thanks |
that is old post. right now is more easy. can by NCK Calculator / make SIMLOCK rpl. just searching in our sticky post . br, |
