Old 02-09-2010, 13:07   #1 (permalink)
khokonhajigonj's Avatar
Member: 771795
Sonork: 771795
Thanks Meter: 120
Success two security TEST failed but faile in one 5220 FAILE
HERE IS 3110 LOG
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 353203
Product Code: 0550542
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353203038034305
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-09-2010, 14:07   #2 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
Originally Posted by khokonhajigonj View Post
HERE IS 3110 LOG
Imei plain: 353203
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
First write clone rpl than do super sd auth n write full pm without (filed 120 n 308).than do recover certificate.
Enjoy..........
Old 02-09-2010, 14:25   #3 (permalink)
shohag's Avatar
Member: 147116
Sonork: 100.1578260
Thanks Meter: 316
1-Backup Rpl full
2- reset NPC
3- write full modified pm
4- restore imei
5- Repair SD
6- Super SD auth
7- write pm 1 and 309 field only
8- Default all setting
Tested solution.......
Old 02-09-2010, 14:38   #4 (permalink)
Member: 771795
Sonork: 771795
Thanks Meter: 120
Originally Posted by shohag View Post
1-backup rpl full
2- reset npc
4- restore imei
5- repair sd
6- super sd auth
8- default all setting
tested solution.......
also follow this but not ok
Old 02-09-2010, 15:21   #5 (permalink)
Member: 771795
Sonork: 771795
Thanks Meter: 120
Originally Posted by ashraf_bcs View Post
first write clone rpl than do super sd auth n write full pm without (filed 120 n 308).than do recover certificate.
enjoy..........
cloone rpl system???????????????/////////
Old 02-09-2010, 15:38   #6 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
This is the 5220 clone rpl for u.Write it like original rpl write.
But u didn't post 5220 log?????
File Type: rar 5220_without_NPC_DATA__made_by_MxKey.rar (694 Bytes, 22 views)
bb5 test points all boxes in one cellcarekphb AdvanceUFS 3 11-08-2008 11:57
bb5 test points all boxes in one cellcarekphb BB5 Box by D.K. 5 09-26-2008 11:12
bb5 test points all boxes in one cellcarekphb J.A.F. V-SPEC 0 07-23-2008 12:40
Page generated in 0.17680 seconds with 10 queries
