nokia 6120 SECURITY_TEST failed! sitll nokia 6120 SECURITY_TEST failed! sitll many time i try load rfbb from sever write pm but sitll Phone Type: RM-243 (Nokia 6120) SW Version: V 06.01 02-09-08 RM-243 (c) Nokia Imei plain: 359808xxxxxxxx Product Code: 055xx ApeCoreSw: 06.01 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SECURITY_TEST failed! Imei net: 3598080xxxxxxx Version: SIMLOCK SERVER Provider: Vodafone Espaņa, SAU , Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=21401F Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello IP.ip.ip.ip SUPERDONGLE authorized :)! SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 Updating RFBB data ... Writing section 1... Writing section 309... Done. |
write first rpl without npc data after thet do again sx4 process u get 100% sucess here is rpl without npc http://www.4shared.com/file/n57sGKOb..._NPC_DATA.html |
sir when i write show this logs CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 15000119337400521E46FFBB21D9866B5E4B7F2F ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 10.32.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.). Please select correct loader version from 'Config' menu ! Certificate programmed successfully ! Phone Type: RM-243 (Nokia 6120) SW Version: V 06.01 02-09-08 RM-243 (c) Nokia Imei plain: 3598xxxxx Product Code: 055xxxx ApeCoreSw: 06.01 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SECURITY_TEST failed! Imei net: 359xxxxxxxxx Version: SIMLOCK SERVER Provider: Vodafone Espaņa, SAU , Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=21401F |
CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 15000119337400521E46FFBB21D9866B5E4B7F2F ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0030 - 0040 0221 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 0FE1BA92D924A658E4800780FA6F4868100AC947 TransmissionMode: DDR&TX2 Updating CMT CCC ...OK Updating CMT HWC ...OK Programming Status: [NAND ERROR: 00050800020C000000015900000100Certificate programmed successfully ! Phone Type: RM-243 (Nokia 6120) SW Version: V 06.01 02-09-08 RM-243 (c) Nokia Imei plain: 359808xxxxx Product Code: 055xx ApeCoreSw: 06.01 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SECURITY_TEST failed! Imei net: 359xxxxxxxxx Version: SIMLOCK SERVER Provider: Vodafone Espaņa, SAU , Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=21401F |
many time i try load rfbb from sever write pm but sitll |
give me buzz on ym............ |
f1st save backup rpl 2 erase full 6120 3 full flash 4 write backup rpl and pm full with suppar sd and unlock |
thanks its done ! ......... |
