12-11-2009, 13:42 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: new york
Member: 233618 Status: Offline Thanks Meter: 29 | nokia 6220c unlock error i tried to unlock nokia 6220c v4.13 but no success. please try to make this model supported. Imei net: 35639802xxxxxxx Version: SIMLOCK SERVER Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 2: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F Backup already exist. Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11472, Date: 27-11-2009 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x190C bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1A20 bytes) ...OK Calculating NCK using security server ... Connecting to server[main.mxkey.biz] ...OK, Login ... failed to get key! Reading Simlock info ... Imei net: 35639802xxxxxxx Version: SIMLOCK SERVER Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 2: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F please remove the bug if any in the software. regards, vineet |
12-11-2009, 17:38 | #5 (permalink) | |
Freak Poster Join Date: May 2008
Member: 772286 Status: Offline Thanks Meter: 25 | Quote:
friend try with version 3.2 rev 5.6 that should go. here I can. then post result. here my http://forum.gsmhosting.com/vbb/showpost.php?p=5122960&postcount=718 | |
12-12-2009, 07:48 | #6 (permalink) |
Member: 233618 Status: Offline Thanks Meter: 29 | mx key team please remove the bug in software. if previous version of mx key is able to unlock nokia 6220c and the latest version fails then you must check whats wrong with the software. thanks forum members for reply. any way i unlocked that with geneie. but mx team shud look into the matter ASAP. REGARDS, VINEET |
The Following User Says Thank You to vineet thapar For This Useful Post: |
6220c unlock error | Tadiwa | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 01-16-2010 08:26 |
nokia 6220c unloking error. plz hlp team | peter002 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 01-04-2010 20:40 |
nokia 6220c unlock error | vineet thapar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-11-2009 14:37 |
6220c unlock error | kungpaoski | Cyclonebox | 3 | 05-26-2009 12:57 |
