09-20-2010, 07:14 | #1 (permalink) |
Freak Poster Join Date: Aug 2010
Member: 1358404 Status: Offline Sonork: N/A Thanks Meter: 47 | nokia 6300 SIMLOCK invalid! RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2A900014BCA26D56EBAB0BFAF87AB4D10F0F5E20 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 TransmissionMode: DDR&TX2 Original Imei: 35953701751153 Original Product code: 0555818 Bluetooth ID: 001E3A393CF1 Phone Type: RM-217 (Nokia 6300) SW Version: V 07.30 07-05-09 RM-217 (c) Nokia. Imei plain: 35953701751153-4 Product Code: 0537632 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 359537017511534 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED |
09-20-2010, 07:29 | #4 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | 1 step go to imei tab and click on repair sd for wd timer 2step go to sim lock tab and tick on make simlock rpl and click on spdate sp lock 3step go to pm tab and tick on load rfbb from server and click on super ed auth after phone goes to authentic onn server click om write botton .... now scan your phone all wil be ok |
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post: |
09-20-2010, 07:50 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | Hi go to imei tab imei & security repair SD then go to simlock tick make simlock RPL and update simlock and finally super SD auth and write modifiy PM 1 to 309 reset all BR, |
09-20-2010, 08:04 | #7 (permalink) |
Member: 1358404 Status: Offline Sonork: N/A Thanks Meter: 47 | Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2A900014BCA26D56EBAB0BFAF87AB4D10F0F5E20 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 TransmissionMode: DDR&TX2 Original Imei: 35953701751153 Original Product code: 0555818 Bluetooth ID: 001E3A393CF1 Phone Type: RM-217 (Nokia 6300) SW Version: V 07.30 07-05-09 RM-217 (c) Nokia. Imei plain: 35953701751153-4 Product Code: 0537632 Language Pack: - not available. SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
09-20-2010, 08:18 | #8 (permalink) |
No Life Poster Join Date: Dec 2009 Location: siliguri,india Age: 31
Member: 1183572 Status: Offline Thanks Meter: 203 | 1st make full backup of rpl 2.now reset npc data 3.restore imei 4.repair sd data 5.than make tick mark on make sim rpl than update splock. 6.go in pm tab and make ppm author than write pm from server post logo here. |
09-20-2010, 08:51 | #9 (permalink) |
Member: 1358404 Status: Offline Sonork: N/A Thanks Meter: 47 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 07.30 07-05-09 RM-217 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK Sending CustomLoader(0x50B0 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x3B0 bytes) ...OK Calculating LOCK data ...OK Receiving PM, please WAIT ... OK PM saved to "C:\mobileEx\3.4\data\backup\359537017511534_UNLOC KED_308.1.PM" Writing PM ... OK Completed in 29.031 s Restarting phone ... Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
09-20-2010, 13:00 | #10 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | click identify, and determind by your self you need to tick PA_SL2 or not. read every day: http://forum.gsmhosting.com/vbb/f550...y-here-726058/ BR |
09-21-2010, 21:47 | #13 (permalink) | |
Freak Poster Join Date: Nov 2006 Location: Vozdovac Geto
Member: 388209 Status: Offline Thanks Meter: 47 | Quote:
