02-11-2012, 20:33 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Northern Ireland
Member: 1514899 Status: Offline Thanks Meter: 49 | Nokia 6303 Classic Problem There is a problem when try to read hash file for Nokia 6303 classic: Phone type: RM-443 (Nokia 6303 classic) SW version: V 09.10 25-08-09 RM-443 (c) Nokia Imei plain: 35828103786864-7 Product code: 0585803 Battery voltage: 4870 mV, current: 66 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358281037868647 Version: SIMLOCK SERVER Provider: Orange , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=23433F [United Kingdom-Orange ] BLOCK2: 1=CLOSED(MCCMNC), DATA=23486F and here is what I get when try to read phone's id: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C08xxxxx Using device: HTI, FW ver: 00.50, SN: 0000xxxxx Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Phone type: RM-443 (Nokia 6303 Classic) SW version: V 09.10 25-08-09 RM-443 (c) Nokia ERROR: Packet Error(0xAA), code 0xC0000001 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: *****trap failed! Cable is brand new ordered form company in the UK (DT- 1X148) I tried to get my hti updated to get the latest version but also get error that windowscodecs.dll file is missing |
02-11-2012, 21:25 | #2 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
02-11-2012, 21:47 | #4 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | bro check your cable. 6303i is not same as 6303. do a serch for 6303 pinouts and modify your cable as necessary BR, #zuberchowdhry - pls don't quote entire message if it is just the post above you |
02-11-2012, 22:05 | #5 (permalink) | |
SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358281037868647 Version: SIMLOCK SERVER Provider: Orange , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=23433F [United Kingdom-Orange ] BLOCK2: 1=CLOSED(MCCMNC), DATA=23486F bro. he is getting full info with this cable, so no need to modify cable, the phone RM-443 means 6303 & cable must be too same only, not 6303i so must have understand what i am trying to say. | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
02-11-2012, 23:44 | #7 (permalink) |
Member: 691388 Status: Offline Thanks Meter: 371 | to clarifi this cable problem, I 'l post logs from my wife's phone 6303c - RM443 6303i cable: scan log Code: Phone type: RM-443 (Nokia 6303 classic) SW version: V 10.10 18-11-09 RM-443 (c) Nokia Imei plain: 3515... Product code: 0585358 Battery voltage: 4833 mV, current: 60 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3515... Version: SIMLOCK SERVER Provider: Orange Romania , Country: Romania Counter: 0/3, 0/10 CONFIG_DATA: 2261000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=22610F [Romania-Orange Romania ] Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C0000000 Using device: HTI, FW ver: 00.50, SN: 010111111 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) ERROR: Packet Error(0xAA), code 0xC0000001 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: *****trap failed! Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C0-- Using device: HTI, FW ver: 00.50, SN: 010-- Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Phone type: RM-443 (Nokia 6303 Classic) SW version: V 10.10 18-11-09 RM-443 (c) Nokia ERROR: Packet Error(0xAA), code 0xC0000001 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: *****trap failed! Now working with 6303c cable, also compatible with 3720c: scan log: Code: Phone type: RM-443 (Nokia 6303 classic) SW version: V 10.10 18-11-09 RM-443 (c) Nokia Imei plain: 3515---- Product code: 0585358 Battery voltage: 4819 mV, current: 53 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3515---- Version: SIMLOCK SERVER Provider: Orange Romania , Country: Romania Counter: 0/3, 0/10 CONFIG_DATA: 2261000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=22610F [Romania-Orange Romania ] Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C0---- Using device: HTI, FW ver: 00.50, SN: 010---- Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0410020D8F598E5664F249C0781D50E394A60F2C ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 TransmissionMode: DDR&TX2 Original Imei: 3515------ Original Product code: 0585358 Bluetooth ID: 5C57C8F39C70 Phone type: RM-443 (Nokia 6303 classic) SW version: V 10.10 18-11-09 RM-443 (c) Nokia Imei plain: 3515------------ Product code: 0585358 Battery voltage: 4847 mV, current: 51 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35154--- Version: SIMLOCK SERVER Provider: Orange Romania , Country: Romania Counter: 0/3, 0/10 CONFIG_DATA: 2261000000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=22610F [Romania-Orange Romania ] Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C0--- Using device: HTI, FW ver: 00.50, SN: 010---- Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Phone type: RM-443 (Nokia 6303 Classic) SW version: V 10.10 18-11-09 RM-443 (c) Nokia CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0410020D8F598E5664F249C0781D50E394A60F2C ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Algorithm: RAP3Gv30_XSR14_alg.fg [BB5 ALGORITHM] version: 11.34.0 revision: 3.0 size: 0x81324 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 PUBLIC ID: 0410020D8F598E5664F249C0781D50E394A60F2C PRIVATE ID: 970568FAA2434E1B7FA068EA84C4A592690A377B E-FUSE: C5D5525E SEC ROM CRC: DFAAF68F Restarting phone ... Verifying secure data ...OK HASH: 8404A50AE5BEA65E6803D63DFB933791CD163F41 Verifying RSA signature ...OK, RSA verify passed Hash file saved to "C:\mobileEx\3.5\data\SL3\RM-443_351541xxxxxxxxx.sha" 6303 (RM-443) is different of 6303i (RM-638) BR, Last edited by maremestera; 02-11-2012 at 23:50. |
The Following User Says Thank You to maremestera For This Useful Post: |
02-12-2012, 01:38 | #8 (permalink) |
Member: 1514899 Status: Offline Thanks Meter: 49 | Hi Thanks. I'll post some pictures tommorow cause I get confused as I use cable for 6303 classic and it doesn't read the hash - phone id. The Fonefunshop UK has to explain that to me why cable is not good. |
02-12-2012, 12:40 | #10 (permalink) |
Member: 1514899 Status: Offline Thanks Meter: 49 | Here is a log when I try usb cable, but seems that is not supported : MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0xxxxx Using device: USB Phonet and HTI, FW ver: 00.50, SN: 000xxxxx Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.70 Library ver: 1.0.0.13716(10-01-2012) Phone type: RM-443 (Nokia 6303 Classic) SW version: V 09.10 25-08-09 RM-443 (c) Nokia Phone type: RM-443 (Nokia 6303 Classic) Product code: 0585803 SW version: V 09.10 - 25-08-09 - RM-443 - (c) Nokia LanguagePkg version: 0 - 25-08-09 - RM-443 - (c) Nokia - COR Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1DF490CF CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 144002187D9D8C565DD44A94B9DEDF3B17B970C9 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Loading CMT secondary boot code SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: NEW ERROR: Failed to start boot ! Interface not supported for current operation or not supported phone ! |
02-12-2012, 13:09 | #11 (permalink) |
Member: 1514899 Status: Offline Thanks Meter: 49 | All sorted. Use 3720 classic cable. Thanks for all your support MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C08xxxxx Using device: HTI, FW ver: 00.50, SN: 000xxxxx Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Phone type: RM-443 (Nokia 6303 Classic) SW version: V 09.10 25-08-09 RM-443 (c) Nokia CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 144002187D9D8C565DD44A94B9DEDF3B17B970C9 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Algorithm: RAP3Gv30_XSR14_alg.fg [BB5 ALGORITHM] version: 11.34.0 revision: 3.0 size: 0x81324 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 PUBLIC ID: 144002187D9D8C565DD44A94B9DEDF3B17B970C9 PRIVATE ID: 9C69C79C5FC9B9538F604BE2F4E7F5F5FC75D2E1 E-FUSE: C5D5525E SEC ROM CRC: DFAAF68F Restarting phone ... Verifying secure data ...OK HASH: AD4E83FB0125F8D3111AF509487A1153FC46F096 Verifying RSA signature ...OK, RSA verify passed Hash file saved to "C:\mobileEx\3.5\data\SL3\RM-443_358281037868647.sha" |
02-12-2012, 13:12 | #12 (permalink) | |
Member: 691388 Status: Offline Thanks Meter: 371 | Quote:
BR, | |
The Following 2 Users Say Thank You to maremestera For This Useful Post: |
