12-06-2012, 08:03 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Jul 2011 Location: Dubai U.A.E Age: 36
Member: 1619775 Status: Offline Sonork: 100.1603044 Thanks Meter: 302 | nokia 6303c done by hti green... 1)open hti.. 2)select usb flashing 3)select 6303c 4) click flash. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C086F612 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 00014EBF Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012) Processing MCU file: rm443__10.10.mcusw [BB5,BB5 ALGORITHM] size: 24.67 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 13F001040F938C5698F558A5AD2040A3FA8D0C20 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x69180 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x77780 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 42F2A75 Verifying communication to device OK. Erase size: 28.25 MB CMT FLASH,NOR area [00000000-0001FFFF] erased in 0.844 s CMT FLASH,NOR area [00040000-0005FFFF] erased in 0.953 s CMT FLASH,NOR area [00060000-0007FFFF] erased in 0.844 s CMT FLASH,NOR area [00080000-0015FFFF] erased in 5.578 s CMT FLASH,NOR area [00160000-0023FFFF] erased in 5.531 s CMT FLASH,NOR area [01740000-0191FFFF] erased in 12.500 s CMT FLASH,NOR area [00240000-0173FFFF] erased in 2 min 20.219 s CMT FLASH,NOR area [022E0000-0261FFFF] erased in 21.750 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: E8E6E2AB [RAP Certificate 140 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT ISA+DYNSW block sent Programming completed in 1 min 29.688 s Processing PPM file: rm443__10.10.ppm_a [BB5,BB5 ALGORITHM] size: 6.24 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 9.75 MB CMT FLASH,NOR area [01920000-022DFFFF] erased in 1 min 4.625 s Flash programming ... Programming completed in 24.719 s Processing CNT file: rm443__10.10_ISM_004.image_a_is_matt_black_ctv_dk [BB5,BB5 ALGORITHM] page size: 128 K size: 11.14 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 25.62 MB CMT FLASH,NOR area [02620000-029BFFFF] erased in 32.515 s CMT FLASH,NOR area [029C0000-03FBFFFF] erased in 3 min 19.719 s Flash programming ... Programming completed in 42.485 s Total time for flashing process(boot+erase+write) was 11 min 24.360 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 6303 classic USB Phonet, PORT_ID: 8343074 Verifying communication to device OK. Phone type: RM-443 (Nokia 6303 classic) SW version: V 10.10 18-11-09 RM-443 (c) Nokia Imei plain: 35828103053750-4 Product code: 0569163 Battery voltage: 3755 mV, current: 79 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358281030537504 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
The Following User Says Thank You to Parvez.Alom+H For This Useful Post: |
12-06-2012, 11:20 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Good..... Bro. There is Sticky Thread too for your successful Story, Share here: http://forum.gsmhosting.com/vbb/f550...-mxkey-767051/ Keep it up. BR, ZUBER |
