01-02-2010, 09:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Mobile phone world
Member: 90701 Status: Offline Thanks Meter: 134 | Nokia 6681 startup failed Phone Type: RM-57 (Nokia 6681) SW Version: V 04wk47_m_v14 09-02-06 RM-57 (c) Nokia. Imei plain: 35188601503684-8 Product Code: 0529498 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed ImageFileVersion: 7.11.00 ProductProfile: rm-57_als.pp Imei net: 351886015036848 Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED |
01-02-2010, 09:41 | #3 (permalink) |
Member: 90701 Status: Offline Thanks Meter: 134 | nokia 6681 phone startup failed Hi, Did the SL data repair(Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11446, Date: 25-11-2009 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D Sending SecondaryBoot(0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x0 bytes) ...OK) And when I click update splock i get this: Imei net: 351886015036848 Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11446, Date: 25-11-2009 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D Sending SecondaryBoot(0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x0 bytes) ...OK No change. |
nokia 7610:phone startup failed,contact retailer | The Razor | Nokia Hardware & Hardware Repair | 55 | 07-22-2012 06:13 |
Nokia 6681 startup failed | Unicom | Nokia Base Band 5 ( BB-5 ) | 4 | 01-02-2010 11:06 |
Nokia N70 startup failed | nabelgsm | Nokia Base Band 5 ( BB-5 ) | 3 | 11-07-2008 02:55 |
Nokia N72 Startup Failed | NIMESHFONOTLY | Universalbox | 18 | 08-09-2008 12:42 |
Nokia 6630 - Startup Failed Problem | nshkw | Nokia Hardware & Hardware Repair | 16 | 11-15-2005 02:29 |
