nokia 6790 security test failed a customer brought me to unlock this phone yesterday, when I was doing wrongly elected unlock the simlock init method, and error process led the operation, now give me security breach and the phone goes off every 10 minutes, here I I leave the log. Phone Type: RM-599 (Nokia 6790s-1c) SW Version: V 09w17.03.38 09/09/2009 RM-599 (c) Nokia Imei plain: 35607503090691-3 Product Code: 0594278 ApeCoreSw: 03.38 Language Pack: - Not available. Seems To Be valid SIMLOCK Seems To Be valid SUPERDONGLE_KEY Seems To Be valid WMDRM_PD SECURITY_TEST failed! Net Imei: 356075030906913 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0 / 3, 0 / 10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 2: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 3: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 4: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 5: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 6: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 7: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF I hope I can help with this problem, thanks in advance. |
when u unlock u are mistake to tick make simlock rpl no problem u still repair this one. just press super sd auth or pmm auth write pm u will done |
this is the result when I try to make the authorization of super dongle. SERVER-> Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Using device: POTATO BOX, FW see: 01.B4 Library version: 1.0.0.8955 (29/09/2010) 1.0.0.14639 (29/09/2010) Product: V 09w17.03.38 09/09/2009 RM-599 (c) Nokia ApeCoreSw: 03.38 Using cached productData [18100209D68D005227F610398913C4DF895D0531] ... Authenticating to SUPERDONGLE using server security ... Bad phones ack on step1, SUPERDONGLE_KEY Probably corrupted! Wrong response to SD verify request Elapsed: 3,391 s (session timeout out after 3 second) thank you very much for your help friend. |
and this is the result when I try to make the authorization of pm. Local Scanning SX4 Card ... SX4 Card not found. SERVER-> Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Authenticating using server security ... Connecting to server [main.mxkey.biz] Connection timed out ... Connecting to server [main.mxkey.biz] Connection timed out ... Connecting to server [main.mxkey.biz] Connection timed out ... Retrying ... SERVER-> Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Authenticating using server security ... Connecting to server [main.mxkey.biz] Connection timed out ... Connecting to server [main.mxkey.biz] Connection timed out ... Connecting to server [main.mxkey.biz] Connection timed out ... Retrying ... may be happening? because the authorization does not permit me? |
Please use the new version of Mobile Ex, and then try again but first go to email rebuild option and press the button recover SD, and check the status of security test again and post the results! |
I do not see that button recover sd, sd repair only see |
ah ok yes sorry repair SD |
this is the result of the repair sd. Using device: POTATO BOX, FW see: 01.B4 Library version: 1.0.0.8955 (29/09/2010) 1.0.0.14639 (29/09/2010) Product: V 09w17.03.38 09/09/2009 RM-599 (c) Nokia ApeCoreSw: 03.38 Using cached productData [18100209D68D005227F610398913C4DF895D0531] ... Calculating SUPERDONGLE using server security ... SERVER-> Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Completed in 7312 s RPL saved to "D: \ mobileEx \ 3.4 \ data \ backup \ BB5_RM-599_356075030906913_SD.RPL" Updating ... OK SUPERDONGLE_KEY but the motive remains the same. Phone Type: RM-599 (Nokia 6790s-1c) SW Version: V 09w17.03.38 09/09/2009 RM-599 (c) Nokia Imei plain: 35607503090691-3 Product Code: 0594278 ApeCoreSw: 03.38 Language Pack: - Not available. Seems To Be valid SIMLOCK Seems To Be valid SUPERDONGLE_KEY Seems To Be valid WMDRM_PD SECURITY_TEST failed! Net Imei: 356075030906913 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0 / 3, 0 / 10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 2: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 3: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 4: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 5: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 6: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 7: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF |
Bro the Sx4 server #1 is down, that could be the reason! |
I get here I do not understand sx4 server # 1 online and offline sx4 server # 2. |
no, the two server are offline check again!!!! |
here is the evidence http://img710.imageshack.us/img710/7...veroffline.jpg |
please You can take a look at my situation THROUGH THE vew team remote connection? awhile to achieve the authorization of super dongle, but now gives me corrupted sim lock |
Phone Type: RM-599 (Nokia 6790s-1c) SW Version: V 09w17.03.38 09-09-09 RM-599 (c) Nokia Imei plain: 35607503090691-3 Product Code: 0594278 ApeCoreSw: 03.38 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! SIMLOCK_DATA corrupted! |
please bro take a loock of the phone in team viewer. |
