09-30-2010, 14:09 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Rep Dom Age: 37
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | nokia 6790 security test failed Phone Type: RM-599 (Nokia 6790s-1c) SW Version: V 09w17.03.38 09/09/2009 RM-599 (c) Nokia Imei plain: 35607503090691-3 Product Code: 0594278 ApeCoreSw: 03.38 Language Pack: - Not available. Seems To Be valid SIMLOCK Seems To Be valid SUPERDONGLE_KEY Seems To Be valid WMDRM_PD SECURITY_TEST failed! Net Imei: 356075030906913 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0 / 3, 0 / 10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 2: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 3: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 4: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 5: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 6: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 7: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF I hope I can help with this problem, thanks in advance. |
09-30-2010, 14:17 | #2 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | Quote:
when u unlock u are mistake to tick make simlock rpl no problem u still repair this one. just press super sd auth or pmm auth write pm u will done | |
09-30-2010, 14:26 | #3 (permalink) |
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | this is the result when I try to make the authorization of super dongle. SERVER-> Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Using device: POTATO BOX, FW see: 01.B4 Library version: 1.0.0.8955 (29/09/2010) 1.0.0.14639 (29/09/2010) Product: V 09w17.03.38 09/09/2009 RM-599 (c) Nokia ApeCoreSw: 03.38 Using cached productData [18100209D68D005227F610398913C4DF895D0531] ... Authenticating to SUPERDONGLE using server security ... Bad phones ack on step1, SUPERDONGLE_KEY Probably corrupted! Wrong response to SD verify request Elapsed: 3,391 s (session timeout out after 3 second) thank you very much for your help friend. |
09-30-2010, 14:30 | #4 (permalink) |
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | and this is the result when I try to make the authorization of pm. Local Scanning SX4 Card ... SX4 Card not found. SERVER-> Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Authenticating using server security ... Connecting to server [main.mxkey.biz] Connection timed out ... Connecting to server [main.mxkey.biz] Connection timed out ... Connecting to server [main.mxkey.biz] Connection timed out ... Retrying ... SERVER-> Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Authenticating using server security ... Connecting to server [main.mxkey.biz] Connection timed out ... Connecting to server [main.mxkey.biz] Connection timed out ... Connecting to server [main.mxkey.biz] Connection timed out ... Retrying ... may be happening? because the authorization does not permit me? |
09-30-2010, 14:35 | #5 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Please use the new version of Mobile Ex, and then try again but first go to email rebuild option and press the button recover SD, and check the status of security test again and post the results! |
09-30-2010, 14:47 | #8 (permalink) |
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | this is the result of the repair sd. Using device: POTATO BOX, FW see: 01.B4 Library version: 1.0.0.8955 (29/09/2010) 1.0.0.14639 (29/09/2010) Product: V 09w17.03.38 09/09/2009 RM-599 (c) Nokia ApeCoreSw: 03.38 Using cached productData [18100209D68D005227F610398913C4DF895D0531] ... Calculating SUPERDONGLE using server security ... SERVER-> Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.3 Completed in 7312 s RPL saved to "D: \ mobileEx \ 3.4 \ data \ backup \ BB5_RM-599_356075030906913_SD.RPL" Updating ... OK SUPERDONGLE_KEY but the motive remains the same. Phone Type: RM-599 (Nokia 6790s-1c) SW Version: V 09w17.03.38 09/09/2009 RM-599 (c) Nokia Imei plain: 35607503090691-3 Product Code: 0594278 ApeCoreSw: 03.38 Language Pack: - Not available. Seems To Be valid SIMLOCK Seems To Be valid SUPERDONGLE_KEY Seems To Be valid WMDRM_PD SECURITY_TEST failed! Net Imei: 356075030906913 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0 / 3, 0 / 10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 2: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 3: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 4: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 5: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 6: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF BLOCK 7: 1 = OPEN 2 = 3 = OPEN OPEN OPEN 4 = 5 = OPEN, DATA = FFFFFF |
09-30-2010, 15:12 | #13 (permalink) |
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | please You can take a look at my situation THROUGH THE vew team remote connection? awhile to achieve the authorization of super dongle, but now gives me corrupted sim lock |
09-30-2010, 15:12 | #14 (permalink) |
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | Phone Type: RM-599 (Nokia 6790s-1c) SW Version: V 09w17.03.38 09-09-09 RM-599 (c) Nokia Imei plain: 35607503090691-3 Product Code: 0594278 ApeCoreSw: 03.38 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! SIMLOCK_DATA corrupted! |
