08-13-2012, 16:37 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Nokia 701 Contact the retailer I make flash but no work help-me MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C0XXXXX8 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 01XXXXXA Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Battery voltage: 3923 mV Waiting for USB device removal ... Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 54110004FFFF7C40066FCBC5AEFFF788E16F28E6 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0060 - 0000 0032 [Samsung LH28F800BG] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1D6F746F FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: FEB3BB7481D3E5D0EAC907335A4402A071493D53 Selected firmware certificate matched. Original Imei: 35827204XXXXX2 Original Product code: 059M727 Bluetooth ID: A4E731054661 SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x22C bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 33A25588 Verifying communication to device OK. Phone type: RM-774 (Nokia 701) SW version: V 79u_11w34_1 02-09-11 RM-774 (c) Nokia ApeCoreSw: 111.020.0307 Imei plain: 35827204XXXXX2-9 Product code: 059M727 Battery voltage: 3733 mV, current: 168 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35827204XXXXX29 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Phone Type: RM-774 SW version: V 79u_11w34_1 02-09-11 RM-774 (c) Nokia ID Test name Startup Result 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF N passed 3 EAR_DATA_LOOP N passed 12 SIM_CLK_LOOP Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 90 PWR_KEY N passed 2 CURRENT_CONS N passed 96 HOOKINT N passed 101 BTEMP N passed 23 KELVIN_BATVOLTAGE N passed 19 KELVIN_VIBRA N passed 26 KELVIN_CAPACITOR N passed 29 KELVIN_MISC N passed 31 KELVIN_CHARGING N passed 27 KELVIN_AUDIO N passed 116 KELVIN_XEAR N !no signal 34 USB_CHARGING N passed 117 DIGIMIC N passed 209 HEADSET_AMPLIFIER N passed 222 LED_CONTROLLER N passed 233 AUDIO_PLL N passed 239 RAM_IF N passed 128 CDSP_SLEEPCLOCK_FREQ N passed 86 CDSP_RF_BB_IF N !no signal 124 CDSP_STROBE N !no signal 125 CDSP_DIGI_RXTX_IF N !no signal 83 CDSP_RF_SUPPLY N !no signal 127 CDSP_PA_ID_PIN N !no signal 75 CDSP_WCDMA_TX_POWER N !no signal 7 KEYBOARD_STUCK N passed 21 BT_IF N passed 22 CAMERA_IF N passed 5 CAMERA_ACCELERATOR N passed 37 SEC_CAMERA_IF N passed 121 LED_FLASH N passed 44 BT_AUDIO_IF N passed 59 MAIN_LCD_IF N passed 64 TOUCH N passed 103 TOUCH_IF N passed 71 BT_WAKEUP N passed 72 WLAN N passed 97 MASS_MEMORY_IF N passed 104 ACCEL_IF N passed 49 VIBRA N passed 91 USB_LOOP N passed 201 MAGNETOMETER N passed 232 USB_CHARGER_IF N passed 229 LED_FLASH_IF N passed 230 NFC N passed 231 NFC_ANTENNA N passed 94 GPS N passed 99 PROXIMITY N passed MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C086XXX8 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100XXXA Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Reading Important data ... NPC_DATA is empty. SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK WLAN_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35827204567232_PM .rpl" Processing MCU file: RM-774_111.020.0307_79u_prd.core.fpsx [BB5,XSR 1.6] size: 118.90 MB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 Battery voltage: 4024 mV Version from phone: Version from file: 111.020.0307 Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1D6F746F Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 54110004FFFF7C40066FCBC5AEFFF788E16F28E6 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0060 - 0000 0032 [Samsung LH28F800BG] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1D6F746F FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x22C bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backu\BB5_35827204XXXXX2_CER T.rpl" CMT PAPUBKEYS HASH: FEB3BB7481D3E5D0EAC907335A4402A071493D53 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 360.56 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [010C0000-170FFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT SOS+DECOMP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: FEB3BB74 [RAP Certificate v1 257] sent CMT GENIO_INIT block sent CMT SOS+IVE3A block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 18.282 s Processing PPM file: RM-774_111.020.0307_23.01_LTA_and_Brazil_79u_prd.rofs 2.fpsx [BB5,XSR 1.6] size: 50.58 MB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 Erase size: 100 MB CMT FLASH,MuxOneNAND area [0D1C0000-135BFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 7.750 s Processing PPM file: RM-774_111.020.0307_387.01_default_79u.2011.36_prd.ro fs3.fpsx [BB5,XSR 1.6] size: 95.25 KB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 Erase size: 59.41 MB CMT FLASH,MuxOneNAND area [01678000-0169FFFF] CMT FLASH,MuxOneNAND area [135C0000-170FFFFF] Flash programming ... CMT SOS+ROFS3 block sent CMT SOS+IVE3B block sent Programming completed in 0.031 s Processing CNT file: RM-774_M018.08.emmc.fpsx [BB5,XSR 1.6] size: 1018.22 MB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 No Erase header defined, erase will be skipped Erase skipped. Flash programming ... Programming completed in 59.672 s Processing CNT file: RM-774_111.020.0307_387.01_default_79u.2011.36.uda.fp sx [BB5,XSR 1.6] size: 224.81 MB Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108 Erase skipped. Flash programming ... Programming completed in 41.562 s Total time for flashing process(boot+erase+write) was 2 min 34.407 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 33A25588 Verifying communication to device OK. After Flash Processing ... Reseting Factory Values OK. Phone type: RM-774 (Nokia 701) SW version: V 79u_11w34_1 02-09-11 RM-774 (c) Nokia ApeCoreSw: 111.020.0307 Imei plain: 35827204XXXXX2-9 Product code: 059M727 Battery voltage: 3730 mV, current: 163 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35827204XXXXX29 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.172 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.703 s |
08-13-2012, 17:53 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Go to Service Tab > Action Tab > Format File System Menu, Click Scan & Click Format System. After Format Reset All will do your job. BR, ZUBER |
