07-11-2010, 13:59 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: noida Age: 47
Member: 230569 Status: Offline Sonork: 1608865 Thanks Meter: 271 | nokia 7210 simlock invalid SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35693003286683-0 Product Code: 0581686 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_DATA corrupted! repair after siplock SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[189002138F6163501027CF2131BE8BDA8E4C8B49] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Completed in 1.860 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_356930032866830_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... SIMLOCK_DATA corrupted! full erase mobile flash new ver full flash plz help mxkey team |
07-11-2010, 15:13 | #3 (permalink) |
Member: 230569 Status: Offline Sonork: 1608865 Thanks Meter: 271 | SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[189002138F6163501027CF2131BE8BDA8E4C8B49] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Completed in 1.718 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_356930032866830_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... SIMLOCK_DATA corrupted! repair simlock but same problem |
07-11-2010, 15:51 | #4 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1247853 Status: Offline Thanks Meter: 71 | Updating SIMLOCK ... error 0x1 100% SOLUTION !!! -------------------------------------------------------------------------------- !!! [+] Updating SIMLOCK ... error 0x1 100% SOLUTION WITH MXKey First method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Repair SIMlock with MXKey 6 - Repair Superdongle with MXKey 7 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) The second method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Full Erase 3 - Full Flash 4 - Restore only NPC Backup Part 5 - Lock the by phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 6 - Repair SIMlock with MXKey 7 - Repair Superdongle with MXKey 8 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) Third method: 1 - taking full Backup IMEI & Security -> Backup RPL (All Section) 2 - Erase Eeprom Section: Flashing-> Advance-> GetAddress, Disable Safe Erase. Enable Eeprom Part only, Click Erase. 3 - Locke the phone by IMEI & Security -> Lock To Provider (MCC+MNC value is not important) 4 - Repair SIMlock with MXKey 5 - Repair Superdongle with MXKey 6 - Super SD Auth, and finally write Full PM(without Field 308-120) (If required Recover Cert) |
