03-19-2010, 08:50 | #1 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 304012 Status: Offline Thanks Meter: 322 | Nokia 7210c SECURITY_TEST failed! SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35196203618641-5 Product Code: 0566807 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2009-07-20T08:46:24Z SW Version: 07.23 Variant Version: 012 ProductProfile: RM436_0566807_07.23_012.spr Simlock: 0566807_simlock.bin Imei net: 351962036186415 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to .:KRISHNA:..:MOBILE:. For This Useful Post: |
03-19-2010, 09:07 | #6 (permalink) |
No Life Poster Join Date: May 2008 Location: Bangladesh
Member: 777523 Status: Offline Sonork: 100.1584558 Thanks Meter: 335 | 7210s,3110c,5130c....and bb5 contact service solved by this method. 5130_Contact Service_Removed.rar |
The Following 3 Users Say Thank You to sagar_lse For This Useful Post: |
03-19-2010, 09:22 | #9 (permalink) | |
Member: 304012 Status: Offline Thanks Meter: 322 | Quote:
03-19-2010, 09:24 | #10 (permalink) |
Member: 304012 Status: Offline Thanks Meter: 322 | SECURITY_TEST failed! Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35196203618641-5 Product Code: 0566807 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Last edited by .:KRISHNA:..:MOBILE:.; 01-14-2011 at 08:00. |
03-19-2010, 09:25 | #11 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | detailed info here about this error Click here --> http://forum.gsmhosting.com/vbb/f550...l-here-945700/ Quote:
The Following 2 Users Say Thank You to hasnain For This Useful Post: |
03-19-2010, 09:25 | #12 (permalink) |
Freak Poster Join Date: Jul 2009 Location: pakistan
Member: 1085109 Status: Offline Sonork: 100.1585163 Thanks Meter: 223 | click super sd auth and write good pm section i and 309 your fone will b ok 100% tested by me . as [email protected] |
03-19-2010, 09:31 | #14 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | 1. back up certificate, Full PM, 2. Erase whole flash, 3. Full flash with any version after erase. 4. Restore Imei, 5. Repair SD, 6. Load good pm with same phone (use PM-120 and 308 Removal) 7 Activate Super dongle and authorise pm 8. Write pm after pm ok reset the phone , press check , will reset and everything ok, |
The Following User Says Thank You to akhil_bbsr For This Useful Post: |
Nokia 7210c SECURITY_TEST failed! | jodhpur_raj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 21 | 03-22-2011 10:11 |
plz help me mr manole . still problem with 7210c SECURITY_TEST failed! | jagdish puri | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-09-2010 13:18 |
Nokia e65 SECURITY_TEST failed![SOLVED] | sebY7676 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-07-2010 20:52 |
after sd repair 7210c SECURITY_TEST failed! | snkhan70 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-03-2010 16:06 |
nokia 3110 SECURITY_TEST failed | CellWorm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 12-04-2009 06:48 |
