01-06-2010, 02:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Welcome Back J.A.F Age: 47
Member: 135200 Status: Offline Sonork: 100.1594691 Thanks Meter: 33 | nokia 7210c ***** Phone Type: RM-436 SW version: V 06.51 23-03-09 RM-436 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 43 LCD N passed 21 LPRF_IF N passed 44 LPRF_AUDIO_LINES N passed 2 CURRENT_CONS N passed 42 RADIO N passed 69 BACKLIGHT Y passed 33 SIM_LOCK N passed 93 SECURITY N !failed ! 71 BT_WAKEUP N passed 96 HOOKINT N passed 88 TAHVOINT Y passed 101 BTEMP N passed 119 IIC N passed 108 EXT_DEVICE N passed 56 CDSP_SLEEPCLK_FREQ N passed 128 CDSP_SLEEPCLOCK_FREQ N passed 86 CDSP_RF_BB_IF N passed 83 CDSP_RF_SUPPLY N passed 80 CDSP_TX_PLL_PHASE_LOCK N passed 81 CDSP_RX_IQ_LOOP_BACK N passed 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) my phone log Original Imei: 35931002 Original Product code: 0572571 Bluetooth ID: 00247D289EE9 Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 06.51 23-03-09 RM-436 (c) Nokia Imei plain: 3593100286 Product Code: 0563611 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 3593100 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Connecting to server ...OK Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 121.247.94.254 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SOME ONE PLZ HELP ME I ALSO DID GENSX4 BY MT BOX AND LOST 12 CREDITS BUT AFTER WRITING SX4 RPL STILL I GET CONTACT SERVICE. |
01-06-2010, 03:22 | #2 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | Bad phones ack, probably SUPER DONGLE_KEY corrupted ! 93 SECURITY N !failed ! that's y u cant authorize to SX4. At PRESENT mx key not supporting SD repair. i think u have to repair security and then sd rebuild .(both need some other tool- credit robbers.) just check ur private message in box regards, NEIL |
01-06-2010, 04:48 | #4 (permalink) | |
No Life Poster Join Date: Apr 2009 Age: 41
Member: 1015389 Status: Offline Sonork: 19830303 Thanks Meter: 526 | Quote:
as you can see the log above superdongle key looks ok so he need to use sx4 auth to write pm on it to remove contact service etc.. if no help simply try other.. | |
01-06-2010, 06:32 | #6 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | Quote:
try again sx4.some time need three or four time.and also check your internet connection. and write ofcourse a good modified pm | |
01-06-2010, 06:45 | #7 (permalink) |
Member: 135200 Status: Offline Sonork: 100.1594691 Thanks Meter: 33 | tried with all boxes [QUOTE=shahinahmed007;5224602]try again sx4.some time need three or four time.and also check your internet connection. and write ofcourse a good modified pm[/QUOTE tried sx4 man times on mx jaf and mt but still same problem internet connection is good also DID GENSX4 BY MT BOX AND LOST 12 CREDITS BUT AFTER WRITING SX4RPL STILL I GET CONTACT SERVICE. plz help. |
01-07-2010, 07:57 | #10 (permalink) |
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | |
01-07-2010, 11:24 | #15 (permalink) |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | you can use sx4 bypass process with original ufsxhwk. it provides offline solution to write modified pm to phone... tested many times and works perfect. |
Compatible Nokia 7210c Dummy Phone | IPMART | ipmart WebShop | 0 | 10-25-2008 08:50 |
Cable (10Pin) Compatible For Nokia 7210C For MT Box | IPMART | ipmart WebShop | 1 | 09-20-2008 08:57 |
Cable Compatible For Nokia 7210C For JAF / UFS HWK | IPMART | ipmart WebShop | 0 | 09-20-2008 08:00 |
Nokia 7210c Dummy Phone - Original | IPMART | ipmart WebShop | 0 | 09-05-2008 12:36 |
