01-27-2012, 13:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Nokia 7230 Can't read SL3 Hash (ANSWERED) Using device: HTI, FW ver: 00.50, SN: 000081D3 Connection status: OHCI:HUB:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Library ver: 1.0.0.13716(10-01-2012) Phone type: RM-604 (Nokia 7230) SW version: V 06.90 26-02-10 RM-604 (c) Nokia CMT Data : SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 0F90000EA01300498A6A941D83AD630F94BE6C58 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 ERROR: Configuration request failed ! Unknown ID ! Error getting boot info ! ERROR: *****trap failed! Any solution?, i m using Fbus cable i need help please. |
01-27-2012, 13:12 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | - do not use usb hub - for sure your fbus cable is not working. rap3gv4 phones uses special pinout. anyway, you can use USB. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
01-27-2012, 15:28 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | 7230 SL3 HASH read works ok both on fbus and USB. Tested by myself couple days ago. I\m sorry I saved logs only for buscheck and flashing. I did both ways for comparing SHA files and they were identical. The problem I had was not accepting code 7th or 1st level, even I tried reset counters and factory reset. Job done after flashing latest version and send codes by fbus BR, |
01-27-2012, 16:08 | #4 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: From Uzbekistan
Member: 545722 Status: Offline Sonork: 100.1619680 Thanks Meter: 322 | only read fbus cable Quote:
only read fbus cable | |
01-27-2012, 16:22 | #5 (permalink) |
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | maybe it because i m using UFC4 cable, i will try to buy original fbus cable for HTI, sure by USB it doesn't support, i have tested with different usb cable. Anyway thank you for help |
