Member: 890592
Sonork: 100.1581951 Thanks Meter: 4,429 | Nokia 7230 Flash Successful Within 1 min Quote:
Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010)
Due to USB protocol limitation, certificate backup will be skipped.
NPC_DATA is empty.
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35337704256219_BA CK.rpl"
Processing file: rm598__06.90.mcusw as MCU
[BB5,XSR 1.6] size: 28.75 MB
Supported RAP Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100
Battery voltage: 4155 mV
Phone type: RM-604
Product code: 0590649
SW version: V 06.90 26-02-10 RM-604 (c) Nokia
LanguagePkg version: V 06.90 26-02-10 RM-598 (c) Nokia MEJ
Version from phone: 06.90
Version from file: 06.90
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 12AEBDD4
RAP SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x]
RAP EM0 ID: 00001040
RAP EM1 ID: 00001030
RAP PUBLIC ID: 21100002102700499522F31708ABAFE297EEF9D9
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
RAP ROM ID: 67E82268F29CEA60
[ADL] Loading CMT secondary boot code
SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 9.48.0 revision: 2.1 size: 0x3BC0
Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
[ADL] Secondary boot loaded.
FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP
FlashID2: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: MuxOneNAND,RAP
[ADL] Loading CMT Update Server Data
Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 2.1 size: 0x7E232
[ADL] Update Server code loaded.
[ADL] Verifying communication to device OK.
RAP PAPUBKEYS HASH: 4431C834027BBA0D18A5ED745CAFA04BA679A74A
Storing certificate [NPC, CCC, HWC, R&D] OK.
Partitioning....
Partitioning complete
Erase size: 37.69 MB
Flash programming ...
CMT PAPUBKEYS: 4431C834027BBA0D18A5ED745CAFA04BA679A74A (RAP Certificate 192 v.1) written.
Programming completed in 40.063 s
Processing file: rm598__06.90.ppm_meaa as PPM
[BB5,XSR 1.6] size: 6.00 MB
Erase size: 8.87 MB
Programming completed in 8.437 s
Processing file: rm598__06.90.image_meaa_0590628_003 as CNT
[BB5,XSR 1.6] size: 12.86 MB
Erase size: 75.06 MB
Programming completed in 17.094 s
[ADL] Device found: nmwcdc\Nokia 7230 USB Generic, ID: 353A5C94
Flashing completed in 3 min 1.437 s
Phone Type: RM-604 (Nokia 7230)
SW Version: V 06.90 26-02-10 RM-604 (c) Nokia
Imei plain: 35337704256219-4
Product Code: 0590649
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353377042562194
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 3 min 3.782 s
Nokia 7230 USB Generic detached.
Thank you MX-Key Team
Delower |
