Old 06-29-2010, 11:18   #1 (permalink)
mayank.gupta's Avatar
Member: 966792
Sonork: 100.1602610
Thanks Meter: 199
Thumbs up NOKIA 7610 phone stat-up faild. contact the retailer
Phone Type: RH-51 (Nokia 7610)
SW Version: V 2006_wk41 11-10-06 RH-51 (c) Nokia.
Imei plain: 35227***********
Product Code: 0517282
Language Pack:
- not available.
Imei net: 352273***********
Version: SIMLOCKLIB VERSION 2.29
Counter: 0/3, 0/10
CONFIG_DATA: 0040000005FFFFFF
PROFILE_BITS: 8BE70008070028FF
PLEASE HELP
Old 06-29-2010, 11:24   #2 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
JUST GO IN IN IMEI AND SECURITY TAB AND SELECT SIMLOCK
THAN MAKE TICK ON SIM LOCL RPL THAN CLICL ON Update splock ur problem will be solve.
Old 06-29-2010, 11:39   #3 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 275
it is only for bb5. it is not bb5 phone.
just format user area. all ok.
Old 06-29-2010, 11:45   #4 (permalink)
Member: 619199
Thanks Meter: 47
ya i agree with u irfan bhai
Old 06-29-2010, 11:48   #5 (permalink)
Member: 170684
Thanks Meter: 19
just manual formate & check
Old 06-29-2010, 12:32   #6 (permalink)
Member: 966792
Sonork: 100.1602610
Thanks Meter: 199
Farmate but failed.............
Old 06-29-2010, 12:36   #7 (permalink)
niceraees's Avatar
Member: 354975
Sonork: Love For All
Thanks Meter: 462
bro use formate and set ok 10000000000000000000 *+3+green butten +power screen show formateing compalate and set can b ok
Old 06-29-2010, 13:42   #8 (permalink)
Member: 966792
Sonork: 100.1602610
Thanks Meter: 199
same problum ji.........
Old 06-29-2010, 17:11   #9 (permalink)
Ramzan's Avatar
Member: 86597
Sonork: 100.1602630
Thanks Meter: 1,131
6670 7610 3230 blank & stat-up faild solution
first of all
this problem happend after wrong flash
or u recive the phone with this problem and normal flashing with mcu and ppm not help to repair this problem
so do next
1- with ufs box start to erase manual this adress
start: 00000000 end: 00FFFFFF
start: 02000000 end: 02FFFFFF
start: 04000000 end: 047FFFFF
this 3 adress will eras the 3 flash's and u will not lost ur phone imei
2- with ufs again erase
start: 00010000 end: 0000FFFF
start: 02000000 end: 00FFFFFF
start: 02FC0000 end: 0286FFFF
start: 02A00000 end: 0000FFFF
3- flash ur phone with latest firmware
4- write full pm to ur phone
5- unlock and format user area
if ur blank phone (7610-6670-3230 ) the problem up to software by this solution will work 100%
if the phone still the same so the problem now is a hardware and this we will look on it sooon
br
CELL ZONE
Old 07-12-2010, 10:32   #10 (permalink)
Sandeepjagdeva's Avatar
Member: 495742
Sonork: N O W H E R E
Thanks Meter: 49
Good work hope it will work for all
Old 07-15-2010, 14:30   #11 (permalink)
Member: 1341683
Sonork: 1431
Thanks Meter: 33
pls send me 7610 updated pm .....
pls
pls
pls
Old 07-15-2010, 15:47   #12 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 140
use .hwk.format ...................
Old 07-15-2010, 15:54   #13 (permalink)
Member: 1341683
Sonork: 1431
Thanks Meter: 33
yah i have hwk ..
n i do full flash...
but problem is no opretor found ..
pls helm me bhaijaan
Old 12-15-2010, 14:26   #14 (permalink)
Member: 1387689
Sonork: dipak
Any body help..6670 start up faild.
it comes with displaying NOKIA
1st-after flashing----- it was same before..
2nd-then formated manually by 3+*+green butten+power--------it was same before--
3rd-Then changed its boot ic,-
arises same problem-------
any sussions ??????????????????????????????????????/
Old 12-15-2010, 14:36   #15 (permalink)
Member: 1091455
Sonork: qq 2250871952
Thanks Meter: 769
10000000000000000000000%%%%%%%% * 3 green + on power screen show formateing compalate and set can b ok
Page generated in 0.19901 seconds with 9 queries
