04-08-2011, 07:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | NOKIA 7610 rh-51 dead (ANSWERED) Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010) Processing MCU file: RH51_52_67_68PE706420.C1 [WD2 BT2,WD2 ALGORITHM] size: 24.51 MB Supported Ids: 0082, 1081 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 008EACA9:2984DA7E Area [00000000-0000FFFF] erased in 0.640 s Area [00010000-00FFFFFF] erased in 2 min 33.781 s Area [02000000-0287FFFF] erased in 1 min 16.703 s Area [02FC0000-02FEFFFF] erased in 1.844 s Flash programming ... Programming completed in 6 min 32.016 s File Processed in 10 min 47.360 s Processing PPM file: RH51PE706420.33 [WD2 BT2,WD2 ALGORITHM] size: 2.62 MB Supported Ids: 0082, 1081 ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 008EACA9:2984DA7E Area [00000000-0000FFFF] erased in 0.641 s Area [02A00000-02C8FFFF] erased in 23.062 s Flash programming ... Programming completed in 42.063 s File Processed in 1 min 25.015 s Flashing completed in 12 min 12.453 s Phone not responding ! |
04-08-2011, 07:32 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | try to fully erase phone first. DCT4 > Flash > Advance > Gett Addr. > don't tick 'Safe Erase' > Select all defined area > press Erase. proceed to normal flashing. If phone still dead after flash, check HW: on most case, flash chip is bad. (the big one) BR |
The Following User Says Thank You to gbluez For This Useful Post: |
