11-25-2014, 09:02 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: aizawl
Member: 282510 Status: Offline Thanks Meter: 33 | nokia ash 305 flash file at market drop down menu it says 059p556 but the file is for 059p553, any1 have 059p556 file plzz share me here is the log: Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0859DFF Using device: USB ROM and HTI, FW ver: 00.50, SN: 01012F93 Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.117 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.49 EBL version: Quantum_Bootloader_10.49_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35367305317682 RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35367305317682_back.RPL) Processing file: rm766__07.42.mcusw Downloading item CODE:rm766__07.42.mcusw_ebl_psi.fls, num block: 4, size: 27.77 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.407 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.360 s Erasing area 0x40060000-0x4011FFFE ...OK Programming completed in 1.313 s Erasing area 0x40120000-0x41BE3FFE ...OK Programming completed in 40.594 s Checksum verified (0x9E48) Processing file: rm766__07.42.ppm_mh Downloading item CUST:package_mh.ppm_ebl_psi.fls, num block: 1, size: 7.48 MB Erasing area 0x41C00000-0x423792A6 ...OK Programming completed in 12.062 s Checksum verified (0x352D) Processing file: rm766__07.42.image_mh_059K9H0_059P553_238_02 Downloading item CUST:rm766__07.42.image_mh_059K9H0_05 , num block: 1, size: 19.88 MB Erasing area 0x42400000-0x43EDFFFE ...OK Programming completed in 31.015 s Checksum verified (0x35D8) Total time for flashing process(boot+erase+write) was 4 min 43.250 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. |
11-30-2014, 08:49 | #2 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
