10-02-2012, 13:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: AT YOUR EYES
Member: 747386 Status: Offline Thanks Meter: 30 | Nokia asha 200 rm 761 hang Phone type: RM-761 (Nokia 200) SW version: V 10.60 20-01-12 RM-761 (c) Nokia Imei plain: 35194405401184-0 Product code: 059J4L0 Battery voltage: 3740 mV, current: 34 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MA3 Language Pack: - not available. Master code: 5646205250 Camera config: 06150123008027, ver: Imei net: 35194405401184 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0840F2D Using device: USB Phonet and HTI, FW ver: 00.50, SN: 010016CF Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Battery voltage: 3800 mV Waiting for USB device removal ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35194405401184 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK LOCK120_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35194405401184_ back.RPL" Processing file: rm761__10.60.mcusw Downloading item CODE:rm761__10.60.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.484 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 1.313 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.735 s Erasing area 0x40280000-0x41A7FFFE ...OK Programming completed in 40.234 s Checksum verified (0xA72F) Processing file: rm761__10.60.ppm_ma3 Downloading item CUSTackage_ma3.ppm_ebl_psi.fls, num block: 1, size: 5.06 MB Erasing area 0x41A80000-0x41F8E7D6 ...OK Programming completed in 15.312 s Checksum verified (0xAC76) Processing file: rm761__10.60.image_ma3_059J4L0_005 Downloading item CUSTackage_ma3_059J4L0.image.fls, num block: 1, size: 14 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 20.985 s Checksum verified (0x6F3A) Total time for flashing process(boot+erase+write) was 9 min 37.297 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 324B268F Verifying communication to device OK. Phone type: RM-761 (Nokia 200) SW version: V 10.60 20-01-12 RM-761 (c) Nokia Imei plain: 35194405401184-0 Product code: 059J4L0 Battery voltage: 3785 mV, current: 49 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MA3 Language Pack: - not available. Camera config: 06150123008027, ver: Imei net: 35194405401184 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.313 s |
10-02-2012, 20:36 | #3 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000 | |
10-03-2012, 08:53 | #4 (permalink) |
Member: 747386 Status: Offline Thanks Meter: 30 | Phone Type: RM-761 SW version: V 11.56 26-03-12 RM-761 (c) Nokia ID Test name Startup Result 33 SIM_LOCK N passed 93 SECURITY N passed 90 PWR_KEY N passed 2 CURRENT_CONS N passed 43 LCD N passed 44 LPRF_AUDIO_LINES N passed 21 LPRF_IF N passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 71 BT_WAKEUP N passed 96 HOOKINT N passed 101 BTEMP N passed 118 RF_ANTENNA N passed 112 CDSP_PA_TX_POWER N passed 227 SLEEP_CLOCK_FREQ N passed 52 KEYB_LINE N passed 10 ADC_IF N passed 50 MEMORY_CARD_IF N passed 53 SIM_MULTIPLEXER_IF N passed 17 RF_PLL N passed 45 FEM_CURRENT N passed 47 SECURITY_FUSE N passed 114 IO_EXPANDER_IF N passed SOLVED BY VR 11.56 THANX |
12-19-2012, 18:01 | #6 (permalink) |
Junior Member Join Date: Sep 2012 Location: indonesia
Member: 1814386 Status: Offline Thanks Meter: 0 | i need help....please!!!!!!!!! i need file flash nokia asha 200 rm 761, i try download with navifirm 1.7 .. can't download at ppm and mcu.. please help me , if you have a link for download this file... thanks before |
