10-30-2013, 13:01 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 686359 Status: Offline Thanks Meter: 0 | Nokia Asha 201 contact service Here is the log from MxKey: MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C087F8B6 Using device: USB ROM and HTI, FW ver: 00.50, SN: 01013E68 Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.115 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.37 EBL version: Quantum_Bootloader_10.37_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD__back.RPL) Processing file: rm799__11.95.mcusw Downloading item CODE:rm799__11.95.mcusw_ebl_psi.fls, num block: 4, size: 25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.406 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.406 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.688 s Erasing area 0x40280000-0x41A3FFFE ...OK Programming completed in 32.110 s Checksum verified (0x394D) Processing file: rm799__11.95 (1).ppm_b1 Downloading item CUSTackage_b1.ppm_ebl_psi.fls, num block: 1, size: 5.74 MB Erasing area 0x41A40000-0x41FFCF66 ...OK Programming completed in 8.922 s Checksum verified (0xF107) Processing file: rm799__11.95 (2).image_b1_059K514 Downloading item CUSTackage_b1_059K514.image.fls, num block: 1, size: 14.88 MB Erasing area 0x42180000-0x43E1FFFE ...OK Programming completed in 22.172 s Checksum verified (0xB418) Total time for flashing process(boot+erase+write) was 7 min 29.875 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia Asha 201 USB Phonet, PORT_ID: 353276052475638 Verifying communication to device OK. Phone type: RM-799 (Nokia 201) SW version: V 11.95 20-12-12 RM-799 (c) Nokia Imei plain: 35327605247563-8 Product code: 059K514 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 115B6002004020, ver: SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! Market items is empty, please select the correct products path ! |
01-16-2014, 01:49 | #2 (permalink) |
Junior Member Join Date: Apr 2009 Location: south africa
Member: 1016673 Status: Offline Sonork: 19841947 Thanks Meter: 0 | I got nokia asha 2010-rm799 I try to flash with atf but stop on da way and phone is dead and if I try conect again shows usb not recogniz I think is usb got problam I need usb pin out any body can help plz |
01-17-2014, 08:33 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
You can do Google search, Check here: http://forum.gsmhosting.com/vbb/f148/ or follow Schematic for good result. BR, ZUBER | |
