11-30-2012, 09:30 | #1 (permalink) |
Junior Member Join Date: Mar 2010 Location: GSM World
Member: 1271408 Status: Offline Thanks Meter: 5 | Nokia Asha 305 dead after flash MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: ******** Using device: USB ROM and HTI, FW ver: 00.50, SN: *********** Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.49 EBL version: Quantum_Bootloader_10.49_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35413105380384 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_354131********_ back.RPL" Processing file: rm766__03.60.mcusw Downloading item CODE:rm766__03.60.mcusw_ebl_psi.fls, num block: 4, size: 27.77 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.344 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.359 s Erasing area 0x40060000-0x4011FFFE ...OK Programming completed in 1.156 s Erasing area 0x40120000-0x41BE3FFE ...OK Programming completed in 36.375 s Checksum verified (0x99D5) Processing file: rm766__03.60.ppm_mh Downloading item CUSTackage_mh.ppm_ebl_psi.fls, num block: 1, size: 7.74 MB Erasing area 0x41C00000-0x423BCADE ...OK Programming completed in 10.563 s Checksum verified (0x6759) Processing file: rm766__03.60.image_mh_059K9H0_059P553_238_01 Downloading item CUST:rm766__03.60.image_mh_059K9H0_05 , num block: 1, size: 14.88 MB Erasing area 0x42400000-0x43EDFFFE ...OK Programming completed in 20.516 s Checksum verified (0x3772) Total time for flashing process(boot+erase+write) was 4 min 16.938 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1C0E41AE |
