nokia c1-01 Contacr service Hi, I can resolve the problem "Contact Service" for a Nokia c1-01 whith HTI Plus ? |
Write full flash,And next time POST LOG |
Yes dear you should give us log then it is easy to reactfy the problem |
I connect the nokia c1-01 via USB and it is not recognized. I don't have the FBUS cable. I am forced to use FBUS cable ? thanks. |
try clean and change usb connector and try phone detect by usb. and show hardware id missing... it not problem. B,R-chamisrilanka |
Hi, this is the message : Quote:
BR, Zuber |
hi, i flash thr nokia c1-01 with Nokia Phoenix (with the usb dead option). And survives until the problem. At a moment after the 100% flash the phone go to test mode and return to "Contact Service". Help me Please !! Thanks. |
hi do a local mode and the code is : Quote:
and Quote:
- added: Quick Fix for XGOLD2 Fix CS/Recover SIMLOCK (This will recover SIMLOCK table caused by Reset LOCK counter) https://lh4.googleusercontent.com/-d.../35_rev23b.png BR, Zuber |
ok. it's done !!! thank you VERY MUCH !!!!! MXKEY is the best ! |
hi, the contact service problem has resolved. And i have a simlock code by Orange france and the phone says "Impossible to remove simlock" why ? code to remove simlock : 954636833224154 (for c1-01 351957050554001) thanks !!! |
C1-01 infenion you can't remove via code..... brutforce by superpc and mxkey... |
ok. i'm going to send to Orange service special. thank you ! bye. |
can i Quick Fix for XGOLD2 Fix CS/Recover SIMLOCK ? by usb connection ? if not can someone give me the testpoint for c1-01 ? |
