07-27-2012, 06:59 | #1 (permalink) |
Freak Poster Join Date: May 2011 Location: Himachal Pradesh,Kangra,India
Member: 1587904 Status: Offline Thanks Meter: 59 | Nokia C2-03 in Local Mode After flashing Number of Image Files: 3 Processing Image File : rm702__07.31.mcusw Processing Image File : rm702__07.31.ppm_bg Processing Image File : rm702__07.31.image_bg_059L5S2 AUTO SELECTED DEAD USB FLASHING... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Sections : 04 Current File : rm702__07.31.mcusw Compile Name: rm702__07.31.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 29363592 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 04 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: EE63 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 04 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7AB2 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 04 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: F204 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 of 04 FIRMWARE Erase Block: 0x40280000~0x41DBFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 28049408 bytes Data Checksum: E119 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Data Verification Successful... Sections : 01 Current File : rm702__07.31.ppm_bg Compile Name: package_bg.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4802792 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x41DC0000~0x424BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4799448 bytes Data Checksum: 5681 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Sections : 01 Current File : rm702__07.31.image_bg_059L5S2 Compile Name: package_bg_059L5S2.image.fls Image Type : CONTENT Package Data Size : 11799824 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x424C0000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 11796480 bytes Data Checksum: F7FB Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:03:18 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 07.31 12-01-12 RM-702 (c) Nokia IMEI Plain : 12345610654321? IMEI Spare : A123456106543210 IMEI SV : 31234561065432111F Phone Model: K C2-03 Category : Phone Phone Type : RM-702 ================================================ Extended Phone Information ================================================ Product Serial Number: C9F487EAI Product Code : 059H0R7 Module Code : 0204666 Basic Production Code: 0593195 Long Production SN : 0 PPM SW Version : V 07.31 12-01-12 RM-702 (c) Nokia BG BT MCM Version : 19b5-22012 MCU SW Version : V 07.31 12-01-12 RM-702 (c) Nokia HW Version : 2000 RFIC Version : Dummy RFIC version LCD Version : TPO FWID Version : jV 07.31 12-01-12 RM-702 (c) Nokia V 07.31 12-01-12 RM-702 (c) Nokia BG 059H0R7 001 Content Pack Version : Content: bg_059L5S2 V 07.31 12-01-12 RM-702 (c) Nokia Bluetooth ID : 00:02:5B:00:A5:A5 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0000000000000000 PROFILE_BITS : 0000000000030000 ASIC : 11 PROVIDER : Unknown Provider Unable to read SP Data.. SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 06150123 DCC Ver: 007025 Status : OK |
07-27-2012, 19:35 | #3 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Karachi pakistan
Member: 1449003 Status: Offline Sonork: tariq (100.1603714) Thanks Meter: 38 | rm702__07.31 flash with Product Code....because 7.21 some files are now Available by Code.....and you can also manual try to normal mode.... |
07-28-2012, 03:17 | #5 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: Basirhat
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | Quote:
Are you sure you flash the set with MX Key ? I think this is not mx key log ! Flash the set with V 7.57 and use MX KEY dead USB flashing . | |
07-28-2012, 03:45 | #7 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: Hoshiarpur,India Age: 39
Member: 1608238 Status: Offline Thanks Meter: 26 | Quote:
SECURITY_TEST : FAILED So , write pm file & then reset all ... | |
07-28-2012, 18:41 | #9 (permalink) |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | @love864 bro phone is now damage condition, ( i think flash by wrong product) and log not from MX, for slove this go to ur flashing tool selection and post if u have mxbox come to with mx box (good helper are waiting for help mx users) B,R-chami_dongle |
07-28-2012, 22:25 | #10 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | Quote:
