03-30-2013, 09:51 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Wales
Member: 332001 Status: Offline Thanks Meter: 58 | nokia c5-06 phone startup failed contact the retailer how can i solve this issue ? nokia c5-06 phone startup failed contact the retailer here is info with mx box MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C080054A Using device: USB ROM and HTI, FW ver: 00.50, SN: 00000223 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Processing MCU file: RM-816_23.6.015_prd.core.C00 [BB5,XSR 1.6] size: 103.86 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001060 CMT PUBLIC ID: 1A400111CD115940D4F52A28F7A6F35E6DCA7502 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: DA550B5BAAB517409088A3E4F3EB53AC CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2CA4C2DF FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: FCA5CA3CB2B6BE0DD4FAD6075AFCBB8D7972103C Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 159.06 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0A33FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: FCA5CA3C [] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 24.188 s Processing PPM file: RM-816_23.6.015_prd.rofs2.V21 [BB5,XSR 1.6] size: 12.89 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 33.44 MB CMT FLASH,MuxOneNAND area [077D0000-0993FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 3.156 s Processing PPM file: RM-816_23.6.015_C01_prd.rofs3.fpsx [BB5,XSR 1.6] size: 1.21 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 10 MB CMT FLASH,MuxOneNAND area [09940000-0A33FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.297 s Processing CNT file: RM815_816_004_U002.uda.fpsx [BB5,XSR 1.6] size: 8.58 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 79.25 MB CMT FLASH,MuxOneNAND area [0A340000-0F27FFFF] Flash programming ... Programming completed in 2.219 s Total time for flashing process(boot+erase+write) was 41.766 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2CA4C2DF Waiting for USB device removal ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: ABDCF73 Verifying communication to device OK. Phone type: RM-816 (Nokia C5-06) SW version: V ICPR82_11w25.10 08-06-12 RM-816 (c) Nokia ApeCoreSw: V 23.6.015 Imei plain: 35829504397861-2 Battery voltage: 3923 mV, current: 161 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! plz help me with team viewer [email protected] sonork id, 100.1608956 |
03-30-2013, 10:11 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. This Rapu Based Phone with SL3 Simlock, You cannot solve it with any Tool, Accept previous Backup of this Phone or have to buy Factory RPL to solve it. BR, ZUBER |
04-01-2013, 06:47 | #6 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
You from Pakistan, Then contact: GsmEasy He may help you in this case. BR, ZUBER | |
03-30-2014, 16:03 | #7 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1888830 Status: Offline Sonork: [email protected] Thanks Meter: 4 | pkey@ufs3 box flash but set on nokia logo restart set.plzzzzzzzzz helpp meeeee urzenttttttttttt |
