Old 03-29-2012, 06:42   #1 (permalink)
.:TithiMobile:.'s Avatar
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
Nokia C7 RM-675 Dad after Usb Flash Please help me (ANSWERED)
MXKEY [FT SCR2000 0], SN: C0832583
Using device: USB ROM
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.73
Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012)
Processing MCU file: RM-675_022.014_79.92_prd.core.fpsx
[BB5,XSR 1.6] size: 123.05 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001030
CMT PUBLIC ID: 06D0001710D10344BCDB5A3A790E3D250ED733BE
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0068 - 0000 0131 [Samsung LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1EC4B54F
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x178 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35596004798296_CE RT.rpl).
CMT PAPUBKEYS HASH: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F
Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
Partitioning....
Partitioning complete
Erase size: 489.06 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF]
CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 95A68E9F [RAP Certificate v1 263] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 23.352 s
Processing PPM file: RM-675_022.014_24.01_India_79.92_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 26.92 MB
Erase size: 59.25 MB
CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 5.093 s
Processing PPM file: RM-675_022.014_00.01_79.92_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 4.80 KB
Erase size: 15 MB
CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 0.025 s
Processing CNT file: rm675_ENO_v_0.0491_APEONLY.fpsx
[BB5,XSR 1.6] size: 4.34 MB
Erase size: 5 MB
CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF]
CMT SOS*ENO block sent
Programming completed in 0.812 s
Processing CNT file: RM-675_022.014_U05.01_79.92.uda.fpsx
[BB5,XSR 1.6] size: 154.97 MB
Erase size: 503.50 MB
CMT FLASH,MuxOneNAND area [0E980000-2E0FFFFF]
Programming completed in 35.133 s
Total time for flashing process(boot+erase+write) was 1 min 19.358 s
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
The Following User Says Thank You to .:TithiMobile:. For This Useful Post:
Old 03-29-2012, 07:02   #3 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
ok i will try and will post result thanks
Old 03-29-2012, 08:55   #4 (permalink)
Member: 570024
Thanks Meter: 7
change flash files 100 % ok .... Use latest from MXkey server. i have face same problem
Good Luck...
Old 03-29-2012, 09:07   #5 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
same vibrat only
Driver: nmwcdnsuc, ver: 7.1.32.73
Processing MCU file: RM-675_025.008_79.92_prd.core.fpsx
[BB5,XSR 1.6] size: 123.06 MB
Partitioning....
CMT ADA block sent
CMT KEYS block sent
CMT LDSP block sent
Programming completed in 24.312 s
Processing PPM file: RM-675_025.008_31.01_NAM_79.92_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 45.23 MB
Programming completed in 9.354 s
Processing PPM file: RM-675_025.008_00.01_79.92_prd.rofs3.fpsx
Erase size: 15 MB
Programming completed in 0.065 s
Erase size: 5 MB
Programming completed in 0.870 s
Processing CNT file: RM-675_025.008_U010.01_79.92.uda.fpsx
[BB5,XSR 1.6] size: 146.65 MB
Programming completed in 30.127 s
Total time for flashing process(boot+erase+write) was 1 min 17.954 s
Aborting operation ...
Please help me any body know any good version flash file please tell me and give me link also please help me mxkey team
Old 03-29-2012, 09:10   #6 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
Can u tell me
Good Luck...
can u tell me please which vertion i can flash and which product code please help me bro
Old 03-29-2012, 09:15   #7 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. dont do any experiment as there is a simple solution for vibrate only, go to service>quick fix>tick rap3nand erase>click do selected job & do full factory reset, your problem will be solve. have a nice day.
Old 03-29-2012, 09:45   #8 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Use HTI FiRe Agent to download any Symbian Belle firmware. Version is 111.x.x.x
Use that version to flash the phone.
Additional info:
All C7 firmware can be used one another, ignore RM version.
The Following User Says Thank You to gbluez For This Useful Post:
Old 03-29-2012, 12:44   #9 (permalink)
Member: 545722
Sonork: 100.1619680
Thanks Meter: 322
Update bella............................................. ..
Old 03-29-2012, 12:54   #10 (permalink)
easir.comilla_e's Avatar
Member: 1488757
Thanks Meter: 98
Partitioning....
CMT ADA block sent
CMT KEYS block sent
CMT LDSP block sent
Erase size: 15 MB
Erase size: 5 MB
bor...same...phone...code...same...flash...file
Old 03-29-2012, 12:57   #11 (permalink)
Member: 1488757
Thanks Meter: 98
Phone Type: RM-607 (C1-01)
SW Version: V 05.45 22-06-11 RM-607 (c) Nokia
Imei plain: 35933204388981-9
Product Code: 0596697
Battery voltage: 3745 mV, current: 96 mA
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
Imei net: 35************
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.062 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 1.172 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 1.266 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 0.907 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 1.047 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 1.016 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 1.015 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 1.000 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 1.110 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 0.813 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 1.640 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 2.172 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 1.156 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Nokia C1-01 USB Phonet detached.
http://forum.gsmhosting.com/vbb/8275190-post10.html
The Following User Says Thank You to easir.comilla_e For This Useful Post:
Old 03-29-2012, 13:20   #12 (permalink)
NOKIA_PLUS's Avatar
Member: 1547481
Thanks Meter: 27
bro try file ver.111.30.609 phonix_service_softwar work 100% post result
The Following User Says Thank You to NOKIA_PLUS For This Useful Post:
Old 03-29-2012, 13:23   #13 (permalink)
NOKIA_PLUS's Avatar
Member: 1547481
Thanks Meter: 27
bro try file ver.111.30.609 usb flash phonix_service_softwar work 100% post result
Old 03-29-2012, 14:17   #14 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
Problem Solved With ver 111.30.609
thanksssssssssssssssssssssssssssssssss a lot
Old 03-29-2012, 14:18   #15 (permalink)
Member: 629327
Sonork: 100.1663374
Thanks Meter: 537
Processing MCU file: RM-675_111.030.0609_79u_prd.core.fpsx
[BB5,XSR 1.6] size: 120.12 MB
Partitioning....
CMT ADA block sent
CMT KEYS block sent
CMT SOS+DECOMP block sent
CMT SOS+IVE3A block sent
CMT LDSP block sent
Programming completed in 25.311 s
Processing PPM file: RM-675_111.030.0609_24.01_India_79u_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 30.65 MB
Programming completed in 6.224 s
Processing PPM file: RM-675_111.030.0609_00.01_79u_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 14.48 KB
Erase size: 15.16 MB
CMT FLASH,MuxOneNAND area [01378000-0139FFFF]
CMT SOS+IVE3B block sent
Programming completed in 0.045 s
Processing CNT file: rm675_ENO_v_0.0514_APEONLY.fpsx
[BB5,XSR 1.6] size: 4.73 MB
Erase size: 5 MB
Programming completed in 0.853 s
Processing CNT file: RM-675_111.030.0609_U05.01_79u.uda.fpsx
[BB5,XSR 1.6] size: 155.94 MB
Programming completed in 33.109 s
Total time for flashing process(boot+erase+write) was 1 min 24.786 s
Device connected: nmwcdc\Nokia C7-00 USB Phonet, PORT_ID: B99C887
Verifying communication to device OK.
Phone type: RM-675 (Nokia C7-00)
SW version: V 79_sr1_11w42.5 25-11-11 RM-675 (c) Nokia
ApeCoreSw: 111.030.0609
Imei plain: 35596004798296-8
Product code: 059B8M2
Battery voltage: 3991 mV, current: 260 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355960047982968
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
Completed in 1.150 s
Page generated in 0.42018 seconds with 9 queries
