nokia dct4 not flashing pls help.............. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7948(13-04-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! Processing file: rh37__06.220 as MCU [DCT4,DCT4 ALGORITHM] size: 8.01 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143, 3161, 3160 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! flashing terminated ! Flashing terminated with error(s) in 1 min 44.484 s RX Buffer: F372 |
flash it with UFS only , do not use mxkey with DCT4 sets.... |
mx team plz answer this Quote:
that is not slution where is mx key team plz answer this prob.........:mad::mad::mad: |
we are facing this problem for the last two months but there is no solution yet , but for u , u have the solution in your hand i.e the interface u are using , u can easily repair your set with it ... |
