Old 02-20-2011, 15:22   #1 (permalink)
Member: 140922
Thanks Meter: 6
nokia 5130 all soft wear ok but contact servis
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.95 03-02-10 RM-495 (c) Nokia
Imei plain: 35271704714988-8
Product Code: 0578998
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 352717047149888
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Phone Type: RM-495
SW version: V 07.95 03-02-10 RM-495 (c) Nokia
ID Test name Startup Result
3 EAR_DATA_LOOP Y PASSED(00)
12 SIM_CLK_LOOP Y PASSED(00)
13 SIM_IO_CTRL_LOOP Y PASSED(00)
15 SLEEP_X_LOOP Y !FAILED(01)
46 UEM_CBUS_IF Y PASSED(00)
7 KEYBOARD_STUCK N !NOT EXECUTED(03)
22 CAMERA_IF N !NOT EXECUTED(03)
20 BACKUP_BATT N !NOT EXECUTED(03)
43 LCD N !NOT EXECUTED(03)
21 LPRF_IF N !NOT EXECUTED(03)
44 LPRF_AUDIO_LINES N !NOT EXECUTED(03)
2 CURRENT_CONS N !NOT EXECUTED(03)
42 RADIO N !NOT EXECUTED(03)
69 BACKLIGHT Y PASSED(00)
33 SIM_LOCK N PASSED(00)
93 SECURITY N PASSED(00)
71 BT_WAKEUP N !NOT EXECUTED(03)
96 HOOKINT N !NOT EXECUTED(03)
88 TAHVOINT Y PASSED(00)
101 BTEMP N !NOT EXECUTED(03)
119 IIC N !NOT EXECUTED(03)
108 EXT_DEVICE N !NOT EXECUTED(03)
56 CDSP_SLEEPCLK_FREQ N !NOT EXECUTED(03)
128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03)
86 CDSP_RF_BB_IF N !NOT EXECUTED(03)
83 CDSP_RF_SUPPLY N !NOT EXECUTED(03)
80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03)
77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03)
Old 02-20-2011, 16:22   #2 (permalink)
Member: 140922
Thanks Meter: 6
i am still wating for answer
Old 02-20-2011, 16:28   #3 (permalink)
Member: 274436
Thanks Meter: 26
15 SLEEP_X_LOOP Y !FAILED(01) hardware problem, open phone and chek inside.
Old 02-20-2011, 16:32   #4 (permalink)
GSM DON1's Avatar
Member: 1321028
Thanks Meter: 109
-sir i have same problem .................
Old 02-20-2011, 16:36   #5 (permalink)
Member: 140922
Thanks Meter: 6
YES
witch ic or jumper can solve problem need help with picther
Old 02-20-2011, 16:44   #6 (permalink)
Ali Ahammad's Avatar
Member: 1350057
Sonork: Not use
Thanks Meter: 36
Re-hot power ic
I have done 3110c
Old 02-20-2011, 17:09   #7 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
change avilma ic 100% i solve many time try and post result
Old 02-20-2011, 17:38   #8 (permalink)
Member: 1519660
Thanks Meter: 2
agree, yes change AVILMA because the voltage SLEEP_X and PURX from this IC and distribution to RAP3G.
B,R
Sparrow
Old 02-20-2011, 19:22   #9 (permalink)
Member: 140922
Thanks Meter: 6
i change avlima ic its still same contact servis
Old 02-20-2011, 19:34   #10 (permalink)
Member: 140922
Thanks Meter: 6
also i change betty ic its still same contact servis
Old 02-20-2011, 19:57   #11 (permalink)
Member: 140922
Thanks Meter: 6
and now i heat bord lite hand around avlima and betty and now is ok mobile is working very good thanks for your Cooperating with Grace
Page generated in 0.16860 seconds with 9 queries
