04-01-2010, 10:21 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: INdia
Member: 335008 Status: Offline Thanks Meter: 57 | Nokia E71x Not Supported for SP repair?? Getting Problem With E71x... Was Updating The Phone With New Realsed Mx Key Version 1.7... N get Dead The Phone... Again I tried to revievw the phone with usb but failed...so finally make it alive with another tool... Than restored the RPL with Mx key... Now phone is ok...But Cant repair security keys... ================================================== ================================================== Here is Info logs... Phone Type: RM-462 (Nokia E71) SW Version: V 08w35.03.28 13-08-09 RM-462 (c) Nokia Imei plain: 35687502015999-7 Product Code: 0564434 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356875020159997 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF ================================================== ======= ================================================== ======= While sx4 Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 116.74.113.13 SUPERDONGLE get challenge failed ! ================================================== ======== ================================================== ======== While SD auth: Authenticating to SUPERDONGLE using security server ... ERROR: something went wrong while receiving packet from server (c:1)! ............... whats d prob.... |
The Following User Says Thank You to crazy_kamal For This Useful Post: |
04-01-2010, 11:25 | #4 (permalink) | |
Member: 335008 Status: Offline Thanks Meter: 57 | Quote:
Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Product: V 08w35.03.28 13-08-09 RM-462 (c) Nokia ApeCoreSw: 03.28 Using cached productData[0BA0010DEB700052FFBE96F826C2DC9418EA5CB7] ... Calculating SUPERDONGLE using security server ... Completed in 9.610 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-462_356875020159997_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...OK ================================================ SD Auth logs: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Product: V 08w35.03.28 13-08-09 RM-462 (c) Nokia Using cached productData[0BA0010DEB700052FFBE96F826C2DC9418EA5CB7] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE auth failed! | |
04-01-2010, 11:37 | #6 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | can be from not stable LOCAL / TEST MODE connection . recheck or use another good cable br, |
The Following User Says Thank You to Andra For This Useful Post: |
04-01-2010, 11:48 | #9 (permalink) |
Member: 335008 Status: Offline Thanks Meter: 57 | Scan: Phone Type: RM-462 (Nokia E71) SW Version: V 08w35.03.28 13-08-09 RM-462 (c) Nokia Imei plain: 35687502015999-7 Product Code: 0564434 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356875020159997 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Reapir SD Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Product: V 08w35.03.28 13-08-09 RM-462 (c) Nokia ApeCoreSw: 03.28 Using cached productData[0BA0010DEB700052FFBE96F826C2DC9418EA5CB7] ... Calculating SUPERDONGLE using security server ... Completed in 3.219 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-462_356875020159997_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...OK SD Auth: (1)st try Error reading Pm (2)nd try Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Product: V 08w35.03.28 13-08-09 RM-462 (c) Nokia Using cached productData[0BA0010DEB700052FFBE96F826C2DC9418EA5CB7] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE auth failed! |
04-01-2010, 11:56 | #10 (permalink) | |
The Screen Is Blinking Only.... Not Showing Local Or test Mode.... But I can Scan n bus check..... N getting Info Also... everything Was Bfor Ok untill I flashed the phone with New 1.7.... On that time phone was in local mode, was also showing "LOCAL MODE" On Screen.... I take Rpl Backup Of it... Flashed phone .................n get dead.... With 20-30 unsucssesfull tried, than make full erase the phone...n flashed with JAF to alive it again.... As i restored the rpl with MX key...alldata wrriten ok n suddenly got msg... " Phone Not Responding" Agin I make flash it...with trick as someone described here Uncheck Safe flash n check fast Flash Than....i written only npc data.... than calculated the sd.....now the only pro is security failed.... even i have a full pm backup of it.... But what to do...????? thanks........ | |
04-01-2010, 14:04 | #11 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | bro, flash eno sw then 1_mxkey>serves>imei&securty>imei rebuild>repair sd 2_go to pm >click super sd auth writ pm 1 and 309 and wait 30 second 3_full factory 100% work |
The Following User Says Thank You to alasmmar For This Useful Post: |
04-01-2010, 15:07 | #12 (permalink) |
Member: 335008 Status: Offline Thanks Meter: 57 | Thanks Bro..... But As i Think Its Prob Of not stable LOCAL / TEST MODE connection . For That What Can i do... Tried With # diffrent types of cable... now using Ipmart 2 in 1(Mt-Jaf) cable.... But Still Not success............. |
04-01-2010, 15:25 | #13 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | bro, when u flash eno sw then full flash phone must go to local/test mode use hwk then go to mxkey to repair SECURITY_TEST failed! |
Nokia 5530 not supported for unlock [ANSWERED] | Patrick | Genie Universal | 3 | 03-19-2010 10:04 |
Nokia E71x At&t supported for unlock ? | dannyogolo | Nokia Base Band 5 ( BB-5 ) | 7 | 06-09-2009 12:41 |
Lobster 575 not supported for flash and repair ?! | jawad8305 | FuriousGold | 4 | 11-11-2008 18:24 |
nokia n-75 model not supported for flashing in uni box. | vineet thapar | Universalbox | 0 | 12-19-2007 16:11 |
