11-16-2011, 17:15 | #1 (permalink) |
No Life Poster Join Date: May 2007
Member: 503911 Status: Offline Thanks Meter: 195 | Nokia N73 Phone start up failed contact retailer (SOLVED) Phone type: RM-133 (Nokia N73) SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 35571802665493-7 Product code: 0539299 Battery voltage: 4701 mV, current: 261 mA ApeCoreSw: V 4.0850.43.0.1 ApeVariant: V 4.0850.43.0.1-11 12-12-2008 RM-133 Language Pack: English,02 Uk SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 355718026654937 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F |
The Following User Says Thank You to buntymurarka For This Useful Post: |
11-16-2011, 17:27 | #2 (permalink) | |
Banned Join Date: Aug 2011 Location: India
Member: 1642979 Status: Offline Sonork: 100.1613407 Thanks Meter: 183 | Quote:
repaire simlock 100% working | |
The Following User Says Thank You to anil.prajapati For This Useful Post: |
11-16-2011, 17:38 | #4 (permalink) |
Member: 503911 Status: Offline Thanks Meter: 195 | Imei net: 355718026654937 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F MXKEY [FT SCR2000 0], SN: C0831081 Using device: HTI, FW ver: 00.24, SN: 0000C70D Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Phone type: RM-133 (Nokia N73) SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Using cached productData. PUBLIC ID: 08D00115C0937C5601C48677E01C7019B6D00766 PRIVATE ID: D88FA74D4ACDBBBEE7963DBF420F82713A16358B Updating SIMLOCK...error 0x1 Reading Simlock info ... Imei net: 355718026654937 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
11-17-2011, 06:40 | #5 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | ERASE_308.rar - 4shared.com - online file sharing and storage - download 1st Write this pm file..... then sp unlock then sd repiar then 1&309 pm auth thats all ur set will b working like charm.......... |
The Following User Says Thank You to akashub For This Useful Post: |
11-17-2011, 09:20 | #6 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: pakistan hafizabad
Member: 700741 Status: Offline Sonork: 100.1617188 Thanks Meter: 409 | Quote:
11-17-2011, 13:17 | #7 (permalink) | |
Member: 503911 Status: Offline Thanks Meter: 195 | Quote:
Problem solved by this method.....Thanks | |
03-17-2016, 16:29 | #11 (permalink) |
Freak Poster Join Date: Mar 2015 Location: Nairobi
Member: 2358876 Status: Offline Thanks Meter: 78 | Which tool or Box t use to Flash this, My handset dveloped the same issue and only power on and say " Statrtup faileed. Contact the Reseller"....Heeeelp!!!! |
