11-13-2013, 07:54 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Nokia N79 RM-348 only vibration and blank lcd MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: xxxxxx Using device: USB Phonet and HTI, FW ver: 00.50, SN: xxxxxx Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.84 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: RM-348_31.101_prd.core.fpsx [BB5,XSR 1.5] size: 103.56 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 09B0010E828100520789A96B4EEDE9942784D8A8 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B584 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CERT backup skipped due to protocol limitation. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 165.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-0A95FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: B2075F4B [RAP Certificate 77 v1] sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 1 min 32.937 s Processing PPM file: RM-348_31.101_002_prd.language.fpsx [BB5,XSR 1.5] size: 20.16 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 29 MB CMT FLASH,MuxOneNAND area [08260000-09F5FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 18.313 s Processing PPM file: RM-348_31.101_53.1_prd.customer.fpsx [BB5,XSR 1.5] size: 7.96 KB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 10 MB CMT FLASH,MuxOneNAND area [09F60000-0A95FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.032 s Processing CNT file: vivien_eno_imaker_ape_only.fpsx [BB5,XSR 1.5] size: 2.59 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 4 MB CMT FLASH,MuxOneNAND area [00400000-007FFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 2.344 s Processing CNT file: RM-348_31.101_003_000_U001.uda.fpsx [BB5,XSR 1.5] size: 15.98 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 77.75 MB CMT FLASH,MuxOneNAND area [0A960000-0F71FFFF] Flash programming ... Programming completed in 15.547 s Total time for flashing process(boot+erase+write) was 2 min 16.469 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 22444659 Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 22444659 Help, how to solved problem |
11-14-2013, 18:39 | #5 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2027460 Status: Offline Sonork: [email protected] Thanks Meter: 0 | bro...same problem with me how to solve this ? |
