Old 10-13-2011, 00:52   #1 (permalink)
Member: 1514899
Thanks Meter: 49
Nokia N8 Flashing problem #ANSWERED
Hi
Im trying to flash this N8 and even when all flashed OK, the phone only vibrates and doen't turn on like it would be dead.
This log is just to show my next flashing, before this one flashed went through but couldn't boot the phone:
MXKEY [FT SCR2000 0], SN: C08045AB
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdnsuc, ver: 7.1.32.70
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
Processing MCU file: RM-596_014.002_79.92_prd.core.fpsx
[BB5,XSR 1.6] size: 131.38 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1667F38E
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 1E10020E2BA70344744261050BF4D9B8A0DF03A3
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 228.06 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
WriteDevice failed: Urządzenie podłączone do komputera nie działa
Error while programming [00] at 0x00280400, Result: 0000
Task failed at (0800001C)!!!
Last RX buffer: 80 10 6F 00
As I said it was flashed and no errors, just couldn't boot and now only vibrates and dead.
Old 10-13-2011, 17:52   #2 (permalink)
Member: 1514899
Thanks Meter: 49
Nobody to support??
Can anyone advise me what am I doing wrong?
Old 10-13-2011, 18:03   #3 (permalink)
Moderator
Nizda Mobile's Avatar
Member: 1464783
Thanks Meter: 1,091
try flash with fbus bro!
The Following User Says Thank You to Nizda Mobile For This Useful Post:
Old 10-13-2011, 21:10   #4 (permalink)
Member: 1514899
Thanks Meter: 49
Driver: NMWCD, ver: 7.1.32.62, NTMP ver:
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1D050C87
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1]
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0
FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID2: 00EC 0050 - 0000 0031 [Samsung ] type: MuxOneNAND,CMT
ALG [35]: XSR 1.6
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123
Verifying communication to device OK.
Erase skipped.
CMT ADA block sent
CMT KEYS block sent
CMT PAPUBKEYS: D172C32473AE199B213465ABB3853246F9631231 (RAP Certificate 103 v1) sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 23.109 s
Processing PPM file: RM-596_014.002_01.01_Euro_1_79.92_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 45.75 MB
Erase skipped.
CMT SOS+ROFS2 block sent
Programming completed in 8.532 s
Processing CNT file: RM-596_014.002_U01.01_79.92_prd.uda.fpsx
[BB5,XSR 1.6] size: 56.97 MB
Erase skipped.
Programming completed in 9.562 s
Total time for flashing process(boot+erase+write) was 1 min 18.125 s
Waiting for device boot up ...
Phone not found, retrying ...
And Phone not found. Problem.
Old 10-13-2011, 21:26   #5 (permalink)
Member: 1384141
Flash with 022.014 version.
Old 10-13-2011, 21:36   #6 (permalink)
Member: 320894
Thanks Meter: 7
Flash with24.1 version.
Old 10-13-2011, 22:44   #7 (permalink)
Member: 1514899
Thanks Meter: 49
Driver: NMWCD, ver: 7.1.32.70
Processing MCU file: RM-596_022.014_79.92_prd.core.fpsx
[BB5,XSR 1.6] size: 122.51 MB
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2921A433
CMT PAPUBKEYS is blank/erased.
Erase skipped.
CMT ADA block sent
CMT KEYS block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT LDSP block sent
Programming completed in 23.516 s
Processing PPM file: RM-596_022.014_01.01_Euro_1_79.92_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 53.83 MB
Erase skipped.
Programming completed in 10.188 s
Processing CNT file: RM-596_022.014_U01.01_79.92.uda.fpsx
[BB5,XSR 1.6] size: 90.48 MB
Erase skipped.
Programming completed in 14.297 s
Total time for flashing process(boot+erase+write) was 1 min 36.531 s
Warning: Phone did not reboot to normal mode
Same as before phone is dead
Old 10-13-2011, 22:49   #8 (permalink)
Member: 1423200
Thanks Meter: 53
maybe board problem. what was the fault before?
Old 10-13-2011, 23:03   #9 (permalink)
Member: 1514899
Thanks Meter: 49
24.01 also problem:
Processing MCU file: RM-596_024.001_79.92_prd.core.fpsx
[BB5,XSR 1.6] size: 122.50 MB
Erase skipped.
CMT ADA block sent
CMT KEYS block sent
CMT LDSP block sent
Error while programming [00] at 0x011C0400, Result: 0000
Before flashed first time I noticed that the power button didn't work so I had to disassemby the phone to get the battery out
Can be that sth is wrong with pcb, but why with some core files it flashes full and with some not?
Old 10-14-2011, 00:33   #10 (permalink)
Member: 1423200
Thanks Meter: 53
why not send it to nokia. have you broken the seal?
Old 10-14-2011, 00:40   #11 (permalink)
Member: 1417072
Thanks Meter: 12
try this: after this flash, press power on and after vibration, left telephone for 15-20 minutes... seriously, anytime is problem with first power on...
it si not work, try with cyclone, core+07+uda+fpsx+signature and all is ok probably
after the flash with anna you must press and hold power on button for about 15 second... after all i ok
Old 10-14-2011, 07:02   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Hi
Use HTI + FBUS, apply BB5 Rap3Nand erase (Quick Fix)
Old 10-14-2011, 10:34   #13 (permalink)
Member: 1514899
Thanks Meter: 49
My battery is flat now, can't do anything.
Fbus attach? where?
Old 10-14-2011, 11:06   #14 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
here is N8 cable from us
http://forum.gsmhosting.com/vbb/f693...mxkey-1140637/
Old 10-14-2011, 12:47   #15 (permalink)
Member: 1514899
Thanks Meter: 49
Originally Posted by gbluez View Post
Bought.
Soon I'll reply with the Outcome.
Page generated in 0.28028 seconds with 9 queries
