nokia n82 RM313 Black screen kindly help me (ANSWERED) nokia n82 black screen mx key bus cheak log here kindly help me MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: ********* Using device: HTI, FW ver: 00.50, SN: 010001AC Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: ADD687A6AD1B4A8A7CE32EFD64E59E169D66108F ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0A40010E0E85005871C713920CE5B74BFE022CD8 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 |
try with scan and post log hare |
here is scan log Phone type: RM-313 (Nokia N82) SW version: V 06wk41v64.24 05-11-09 RM-313 (c) Nokia Imei plain: 12345610654321-? Product code: 0561042 Battery voltage: 4726 mV, current: 260 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Latest Nokia N82 software release is 31.0.016 lastly I have rpl Backup |
NAND flash chip is not detected on buscheck above, check APE subsystem (phone HW) |
nokia n82 RM313 Black screen kindly help me kindly guide me phone hardware checking procedure or give me any jumper solution about this ape subsystem failure |
rehot flash ic by using good paste. simple becouse no software problem. |
nokia n82 RM313 Black screen kindly help me? re hot not successes still same condition |
kindly help me kindly help me any body i an in big problem |
Bro. Change LCD or check LCD ways & connector. Post SelfTest logs for better assistance. BR, |
here is self cheak log Phone Type: RM-313 SW version: V 06wk41v64.24 05-11-09 RM-313 (c) Nokia ID Test name Startup Result 46 UEM_CBUS_IF Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 90 PWR_KEY N passed 2 CURRENT_CONS N passed 20 BACKUP_BATT N passed 58 CMT_APE_WAKEUP N !no signal 56 SLEEPCLK_FREQ N passed 42 RADIO N passed 96 HOOKINT N passed 101 BTEMP N passed 8 MBUS_RX_TX_LOOP Y !no signal 108 EXT_DEVICE N passed 86 CDSP_RF_BB_IF N passed 83 CDSP_RF_SUPPLY N passed 85 CDSP_TX_IQ N passed 74 CDSP_TXC_DATA N passed 82 CDSP_PWR_DETECTOR_BIAS N passed 79 CDSP_RX_PLL_PHASE_LOCK N passed 80 CDSP_TX_PLL_PHASE_LOCK N passed 75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
BR, Zuber |
i had this problem too i had one n82 that dead like this after flash backup rpl (only npc data in needed) do full erase with atf write eno file with atf (using add img file in right click menu) flash the phone with 3 files write rpl write pm repair super dongle and splock finally go to "imei and security" in mx and click "recover cert" goodluck |
guide me about this "58 CMT_APE_WAKEUP N " no signal GUIDE ME about this problem any jumper solution or location of AVILMA Ic or related components, Dipok |
1 Attachment(s) Quote:
BR, |
Thats not a hardware fault :D Check rpl and write the rpl your problem were solved. Br. Vijendra Saini. |
