04-18-2013, 07:12 | #1 (permalink) |
Junior Member Join Date: Mar 2007
Member: 459032 Status: Offline Thanks Meter: 0 | Nokia N95 8Gb Dead After Flash Erase Last edited by naseemriaz00; 04-18-2013 at 07:22. |
04-18-2013, 13:41 | #3 (permalink) | |
Member: 459032 Status: Offline Thanks Meter: 0 | Quote:
Imei: 35698301514741 Restoring RF/BB DATA from backup ... Error unable to detect product ! Updating WARRANTY ...error 0x0 Updating PROD ...error 0x0 Updating BT ...error 0x0 MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C087*** Using device: HTI, FW ver: 00.50, SN: 0100*** Connection status: IUSB3XHC:IUSB3HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 3E005B486865C6E30491328A68AAE509640B79E1 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1AA000082E8000582BAB1E31FC90EF73E1753B0B ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 Storage0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,NAND, asic:APE Suggested algorithm: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating APE NPC ...OK Updating APE HWC ...OK Updating APE CCC ...OK Prog.status for Asic APE ... NAND: Status reported bad blocks. NAND: OK | |
04-19-2013, 08:16 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Have you Backup RPL before Erase ? If backed-up, then Download & Flash it with Latest Firmware of your Phone Product Code, Try Quick Fix: Go to Quick Fix Tab > Tick BB5 Rap3NAND Erase > Click Do Selected Job, must solve it, Post full Buscheck Logs if not solve. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
04-19-2013, 11:59 | #5 (permalink) | |
04-20-2013, 07:01 | #6 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Try to Downgrade Phone to lower Version after Erase & don't Restore Backup RPL, Check whether Phone appears in Test Mode with Buscheck, If appears, then Post Buscheck & Selftest Logs, If not, then possibility of Hardware, P.S. But what was the Phone condition before Flashing or Erasing ? Post reply in details. BR, ZUBER |
04-20-2013, 18:58 | #7 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | 1. Flash this ENO file as MCU RM-320_ENO_engine_software_v3.0 - Download - 4shared 2. Flash normal firmware. Old tips worth to read: CLICK HERE |
The Following User Says Thank You to gbluez For This Useful Post: |
05-02-2013, 05:48 | #10 (permalink) | |
Member: 459032 Status: Offline Thanks Meter: 0 | Thank's Alot Quote:
I Well Post Result Thank All Supporter | |
