01-04-2011, 14:06 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: india Age: 43
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | nokia n95 8gb rm-340(SECURITY_TEST failed)! i have nokia n95 8gb , rm-340.its SECURITY_TEST failed!. many try withn mx-key i canot repaier this plz help if any body have perfect solution. thanxx logs here Phone Type: RM-320 SW Version: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia Imei plain: 35954########## Product Code: 0557631 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35954########## Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Last edited by royal_electronics; 01-04-2011 at 14:12. |
01-04-2011, 14:11 | #2 (permalink) | |
Freak Poster Join Date: Nov 2005
Member: 201316 Status: Offline Thanks Meter: 34 | Quote:
01-04-2011, 14:13 | #3 (permalink) | |
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | Quote:
01-04-2011, 14:18 | #4 (permalink) | |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | Quote:
Step 2 - Ask REPAIR SD Step 3 - Click AUTH SUPER SD Step 4 - Now write a full pm, and then unlock with the function Init simlocks (even in SL2 and SL3 ATCS). 100% tested and approved | |
The Following User Says Thank You to paulo pessoa For This Useful Post: |
01-04-2011, 14:50 | #5 (permalink) | |
what u ask sir i canot understand.plz explain. thanxx | |
01-04-2011, 15:00 | #6 (permalink) | |
01-04-2011, 15:04 | #7 (permalink) | |
Phone authenticated to SUPERDONGLE already. Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 1 (4 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 5 (4 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 15 (4 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 27 (4 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 44 (182 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 1.984 s | |
01-04-2011, 15:07 | #8 (permalink) | |
01-04-2011, 15:25 | #11 (permalink) | |
01-04-2011, 15:47 | #12 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Brazil
Member: 232960 Status: Offline Thanks Meter: 419 | Try it: -Check CCC and HWC certificates -How to repair CCC and HWC certificates ? -Backup RPL than open it in notepad -There u will see NPC data after that CCC data and HWC data -Replace only CCC and HWC data with this one "attached", but leave NPC(imei) original -Write your modified RPL in phone -Write pm 1-309 -Reset phone hope it helps... br |
01-05-2011, 06:34 | #14 (permalink) |
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | brother every time when i try ton write pm field 1 & 309 its show this error after click super sd auth. . plz help support logs: SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 ERROR reading PM, please make retry ! |
01-06-2011, 06:43 | #15 (permalink) |
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | no any proper ans by any supporter ?????.i think this time mx-key server not working .any body tell me that mx-key server is working or not this time . becose i try last three days its not work.thanxx |
