07-25-2010, 21:08 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | nokia n95 restarts help me 3o mins before it restarts, when i checked it on mxkey every thing shows okey here is log(1st log) but after some mins i checked it again it shows me that simlock is invalid the 2 logs are below after this i checked again and it showed me SIMLOCK_DATA corrupted!and when i tried to update simlock on mx-key it gave me an error telling me that not a valid imei number which i showed on the third log after a second trial it updated successfully it shows on the 4th log.But when i check the info it shows simlock valid at times and at times it shows simlock invalid pls what do i do? ---------------------------------------------------- 1st log Phone Type: RM-320 SW Version: V 06wk41v64.1 26-09-08 RM-320 (c) Nokia Imei plain: 35482902998307-3 Product Code: 0559497 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354829029983073 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF ----------------------------------------------------------- 2nd log Phone Type: RM-320 (Nokia N95 8GB) SW Version: V 06wk41v64.1 26-09-08 RM-320 (c) Nokia Imei plain: - Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid Imei net: 354829029983073 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF ------------------------------------------------------------ 3rd log SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 SERVER: Not a valid IMEI number (�eø*4›„Dê*—)! Reading Simlock info ... ----------------------------------------------------------- 4th log Imei net: 354829029983073 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 06wk41v64.1 26-09-08 RM-320 (c) Nokia Using cached productData[1A5001067E64005223B1660A6F68409CEA6403BF] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Completed in 3.453 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-320_354829029983073_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF ------------------------------------------------------------------ |
07-27-2010, 03:30 | #4 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Your second log shows:- SIMLOCK invalid! So repair Simlock and if necessary flash with latest version of Firmware. BR |
07-27-2010, 05:59 | #5 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | like i said before at times it show simlock valid at times it shows invalid, i have flashed to the highest version.here is log below that shows valid since it shows simlock valid do i still need to repair simlock? i need solutions!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Phone Type: RM-320 (Nokia N95 8GB) SW Version: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia Imei plain: 35482902998307-3 Product Code: 0559497 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354829029983073 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
07-28-2010, 02:07 | #7 (permalink) |
No Life Poster Join Date: Oct 2009 Location: NIGERIA
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | bro i had a nokia E71 that behaved in a similar way.it defied every so3tware solution until when i dismantled it and reheat the panel and used methilated spirit to brush all the nooks and crannies.it was ok after all.u may try dt.bye |
08-11-2010, 03:26 | #8 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | i have cleaned with spirit,heated ,dried and repaired superdongle,changed battery but problem still persist i am completely confused on what to do still waiting for a solution. |
08-11-2010, 05:09 | #9 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | brother try below step by step , 1 step } repair sd load pm click pmm auth and write pm if your problem not solve try next step 2 step }repair sim lock if your problem not solve try next step 3 step } full flash by update version |
08-15-2010, 04:48 | #10 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | please post here only MXKEY soft. log your problem because your cable. this kind phone is "hungry power" need more power / good BSI value to operation with FBUS cable br, |
