09-06-2010, 20:18 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Age: 36
Member: 1333709 Status: Offline Thanks Meter: 37 | Nokia N96 Start up failed contact the retailer(ANSWERED) This is mx key logo Phone Type: RM-247 (Nokia N96-1) SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia Imei plain: 35932002583710-4 Product Code: 0573063 ApeCoreSw: 30.033 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359320025837104 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFF plz help meeeeeeeeeeeeeeeee |
The Following User Says Thank You to solbh For This Useful Post: |
09-06-2010, 20:55 | #2 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Palestine
Member: 36394 Status: Offline Thanks Meter: 250 | very simple go to Service > Imei and Security > Imei Rebuild > Repair SD then go to PM > SUPER SD Auth and then write the attached pm . good luck |
The Following User Says Thank You to A-H-T For This Useful Post: |
09-07-2010, 08:48 | #7 (permalink) |
Member: 1333709 Status: Offline Thanks Meter: 37 | cannot doing sd auth SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia ApeCoreSw: 30.033 Using cached productData[19F00110DE800052A6BC8E6F5447780954D5B7C5] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
09-07-2010, 13:36 | #8 (permalink) |
Registered User Join Date: May 2007
Member: 507223 Status: Offline Thanks Meter: 80 | Try again and again ,till done ! remove vcc try again what is the first is load the PM 1 & 309,when SD auth done do write Immediately ! AS YOU PHONE ALL IS OK ,ONLY SECURITY_TEST failed! DO THIS YOUR PHONE WILL BE OK ! |
09-07-2010, 17:51 | #9 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Pakistan Age: 36
Member: 158181 Status: Offline Thanks Meter: 113 | Complete solution...... Quote:
auth super dongle and just write that pm ur problem will solve | |
