07-25-2011, 16:28 | #4 (permalink) |
Insane Poster Join Date: Apr 2010
Member: 1278636 Status: Offline Thanks Meter: 6 | MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 5] - C084730D Using device: HTI BOX, FW ver: 00.17 Driver: uhci:hub:ccgp:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.24 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 Flash ID: 0020 8804 [ST 58LR128U,128 Mbits] Processing file: rm732_004.350 Downloading item CODE:hw_s02_rm732_r04.350.fls, num block: 3, size: 5.58 MB Erasing area 0x00000018-0x00160000 ...OK Programming ... flashing terminated ! Task failed at (08000024)!!! Last RX buffer: 0E 00 C2 04 00 00 helppppppppppppppppppppppppppppppppppppppp |
05-17-2012, 17:56 | #6 (permalink) |
No Life Poster Join Date: Jul 2006 Location: ghana
Member: 320120 Status: Offline Thanks Meter: 98 | XKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: xxxxxxxx Using device: HTI, FW ver: 00.50, SN: 00017xxx Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.24 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 0020 8804 - 23280001 [ST 58LR128U,128 Mbits] CFI information: Flash settings: 0/64, size: 0x01000000 2 Block regions: 127 x 0x00020000 = 0x00FE0000 4 x 0x00008000 = 0x00020000 EBL ready ! Processing file: rm713_007.510 Downloading item CODE:hw_s02_rm732_r06.760.fls, num block: 3, size: 5.58 MB Erasing area 0x00000000-0x00005FFE ...OK Programming completed in 0.514 s Erasing area 0x00800000-0x00BEFFFE ...OK Programming completed in 1 min 9.391 s Erasing area 0x00C5D000-0x00DFB6FE ...OK Programming completed in 28.400 s Checksum verified (0xE0CC) Processing file: rm713_007.51ba Downloading item CUST:hw_b1_rm713_007.51ba.fls, num block: 1, size: 4.66 MB Erasing area 0x00100000-0x005A8B7E ...OK Programming ... flashing terminated ! Task failed at (08000024)!!! Last RX buffer: 00 00 00 00 80 01 |
