10-29-2012, 12:53 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: AT YOUR EYES
Member: 747386 Status: Offline Thanks Meter: 30 | Nokia x2-00 rm 618 flash problem NOKIA X2-00 RM 618 AFTER FLASH NOT ON HERE IS LOGS MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0840F2D Using device: USB Phonet and HTI, FW ver: 00.50, SN: 010016CF Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: nmwcdnsuc, ver: 6.85.10.27 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000091A815B31FCBD9070F2D4CDE2095E CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: B653CB3 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738 Selected firmware certificate matched. Original Imei: 35739304022143 Original Product code: 0595304 Bluetooth ID: A8E018ED8CAD SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) ! Last edited by geovicky; 10-29-2012 at 12:59. |
10-29-2012, 14:28 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Your Mxkey Software is back Dated. Use Latest Mxkey from here: http://forum.gsmhosting.com/vbb/f550...hread-1558419/ Check & use Fully Charged Battery, Flash again with same Product Firmware of your Phone. Post reply. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
10-29-2012, 18:50 | #3 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000. | |
10-29-2012, 19:02 | #4 (permalink) | |
Freak Poster Join Date: Aug 2012 Location: jodhpur india Age: 41
Member: 1796401 Status: Offline Sonork: 100.1623409 Thanks Meter: 56 | Quote:
bhai flash karte samay power batan daba ke rakho i hope problam sol ho jayegi | |
10-30-2012, 08:59 | #5 (permalink) | |
Member: 747386 Status: Offline Thanks Meter: 30 | Quote:
br zuber i flash it with new vr 8.35 same product code but ui setting fail | |
10-30-2012, 09:18 | #6 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | It should not happen on Broadcom Based Phones, BTW, try Perform same operation with FBus Cable & post result. BR, ZUBER |
10-30-2012, 11:00 | #9 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Then Follow Erase method from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ & Flash it with Lower Version Firmware of same Product Code will sure comes to Test Mode, If works then Restore IMEI & all necessary Backups & Flash with Latest Firmware. Best of Luck. BR, ZUBER | |
