Member: 343326
Thanks Meter: 1,463 | It is normal Log for 2323C ? Hello to all,
Today i got water damage phone. First i clean this set properly & check the phone. I saw that phone is power on but some time (After 1 - 2 min) phone goes to off. Then i try to flash this set.... Quote:
Using device: J.A.F, FW ver: 01.B2
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
ASIC ID: 0x3168 [UPP_8M ver: 6.4]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
Performing Flash Authentication ...OK
UEM ID: 0054ED15:3B8ADA60
ASIC type: 11
UEM Imei: 351*********25
Flash Imei: 351*********25
RPL saved to "C:\mobileEx\3.3\data\backup\RPL\351*********25_BA CK.rpl"
Processing file: rm543__09.55.mcusw as MCU
[DCT4,DCT4 ALGORITHM] size: 11.56 MB
Supported Ids: 3160, 3161, 3162, 3164, 3166, 3168
FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
Area [01000000-0101FFFF] erased in 0.860 s
Area [01020000-01CFFFFF] erased in 1 min 21.766 s
Flash programming ...
Programming completed in 14 min 49.812 s
File Processed in 16 min 40.922 s
Processing file: rm543__09.55.image_mr_gray as CNT
[DCT4,DCT4 ALGORITHM] page size: 128 K size: 4.25 MB
FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH - COMBO FLASH
UEM ID: 0054ED15:C5A4DA78
Area [02180000-02E7FFFF] erased in 53.813 s
Area [02E80000-02FBFFFF] erased in 10.313 s
Converting UCP blocks to 128 K.
Programming completed in 5 min 2.375 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 0.234 s
File Processed in 7 min 54.375 s
Processing file: rm543__09.55.ppm_mr as PPM
[DCT4,DCT4 ALGORITHM] size: 2.14 MB
UEM ID: 0054ED15:2984DA60
Area [01D00000-0217FFFF] erased in 17.063 s
Programming completed in 2 min 30.344 s
File Processed in 3 min 2.063 s
Flashing completed in 28 min 36.860 s
Phone Type: RM-543 (Nokia 2323c-2)
SW Version: V 09.55 12-11-09 RM-543 (c) Nokia
Imei plain: 351*********25-4
Imei OTP: 351*********25
Product Code: 0587681
Cellular System: GSM
ASIC ID: 0x3168, type: 11
Ppm Id: MR
Language Pack:
- not available.
Imei net: 351*********25
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 28 min 56.594 s | After successful flash this set same condition as before ....But i am confused about it take flash time Total time to process is 28 min 56.594 s
It is normal time to flash this set ?
Also what to do for this problem ? How to solve this ? |
