Old 03-23-2010, 10:36   #1 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
Mx-key new update cant sign application
i install new update with new addons updates but cant sign application i uninstall and install again but the same cant sign application please fix my problem mx key team
br
Old 03-23-2010, 10:41   #2 (permalink)
Member: 172261
Thanks Meter: 364
check internet connection
Old 03-23-2010, 10:50   #3 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
my internet connection is stable afyer installing new update im facing this problem cant sign application
br
Old 03-23-2010, 10:50   #4 (permalink)
Member: 95412
Thanks Meter: 2
I have too problem as you
Old 03-23-2010, 11:03   #5 (permalink)
Member: 95412
Thanks Meter: 2
good solutions!!!!!!
Old 03-23-2010, 11:03   #6 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
Originally Posted by hasnain View Post
uninstall mxkey software
delete C:\MobileEX folder
than install again
after install don't sign first check nokia module update
after that restart app
than sign
thanx
good solution sir after follow your instructions
br
Old 03-23-2010, 11:09   #7 (permalink)
Member: 192751
Thanks Meter: 12
br
i have same problem.
Old 03-23-2010, 11:22   #8 (permalink)
nadim_mobiles's Avatar
Member: 867259
Sonork: 100.1595961
Thanks Meter: 215
than install again
than sign
thn Follow Mr hasnain's TEsted Solution
Old 03-23-2010, 11:24   #9 (permalink)
tomi_no's Avatar
Member: 965
Thanks Meter: 36
not work for me
after that "Connecting server ...
ERROR: Socket is already connected
Old 03-23-2010, 11:25   #10 (permalink)
Uvedovle's Avatar
Member: 10905
Thanks Meter: 109
than install again
than sign
thanx
Is not working for me.
Wbr
Old 03-23-2010, 11:27   #11 (permalink)
Member: 801701
Thanks Meter: 42
not working here either.
program just hangs.
Old 03-23-2010, 11:28   #12 (permalink)
Member: 192751
Thanks Meter: 12
than install again
than sign
for me not working
Old 03-23-2010, 11:29   #13 (permalink)
Member: 201209
Thanks Meter: 5
it was just a server temporary problem,i had it too.Try again,mine solved
Old 03-23-2010, 11:32   #14 (permalink)
Uvedovle's Avatar
Member: 10905
Thanks Meter: 109
Finally worked after try two times and wait, its slow.
Old 03-23-2010, 11:32   #15 (permalink)
Member: 302596
Thanks Meter: 784
Uninstall the antivirus then install MXKEY all works fine
MX Key New UPDATE, TESTED in Flashing 5130c ONLY 5 min boy_muslim MXKEY Nokia Flasher and Unlocker (by Alim Hape) 20 03-23-2010 10:53
MX KEY NEW UPDATE BB5 SIMLOCK DATA/KEY PA SL3 write diljan_07 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 01-29-2010 02:37
mx-key new update problem gsmshapon MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 01-19-2010 09:37
MX Key NEW Update 3.4 saeedullah_khan MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 01-15-2010 07:47
Mx key new update v5.6 ..::Rizwan::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 11-12-2009 23:50
Page generated in 0.26889 seconds with 9 queries
