04-04-2010, 07:29 | #1 (permalink) |
Freak Poster Join Date: Sep 2009
Member: 1126839 Status: Offline Thanks Meter: 28 | 6220 ???? imei but connot write when i log it Code: ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 005E3055:2984DA60 ASIC type: 2 UEM Imei: 35134640047282 Connecting to server ...OK, Login ... |
04-04-2010, 10:40 | #4 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
Check you're hardware first, specially UEM, if there is an error, you will not be able to write UEM data. Also full flash it before tryning to write RPL, that way you can determine if the phone hardware is working properly or not. | |
The Following User Says Thank You to curvenger For This Useful Post: |
04-04-2010, 13:30 | #5 (permalink) | |
Member: 1126839 Status: Offline Thanks Meter: 28 | Quote:
6300 flash complete flsh but connot open | lilong_lee | Infinity-Box | 19 | 09-16-2009 12:33 |
v3 connot write thai | boxtel | Smart-Clip | 1 | 04-06-2006 12:35 |
My K700i IMEI gets reverted back when i unlock it?? | MC Harami | Cruiser Suite | 8 | 12-09-2005 15:00 |
Help:I try to read/write eeprom trim mars ,it say succesful but in fact it failed | winers | Mitsubishi | 1 | 08-02-2001 19:03 |
