03-23-2010, 09:38 | #1 (permalink) |
Insane Poster Join Date: Dec 2008 Location: indonesia
Member: 914576 Status: Offline Thanks Meter: 37 | 1661 Can Unlock with MX-Key but u must use UFS interface Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00DAF0B5:DA3BDA66 ASIC type: 11 UEM Imei: 35525003587728 Flash Imei: 35525003587728 MasterCode: 1621665022 RPL saved to "C:\mobileEx\3.3\data\backup\35525003587728_BACK.rpl" Phone Type: RH-122 SW Version: V 04.30 06-07-09 RH-122 (c) Nokia Imei plain: 35525003587728-3 Product Code: 0572834 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: MD Language Pack: - not available. Failed to read SP data Code: Imei net: 35525003587728 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! PhoneType:RH-122 SwVersion: V 04.30 06-07-09 RH-122 (c) Nokia MCU file: rh122_004.300 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00DAF0B5:2984DA60 Area [01000000-0101FFFF] erased in 0.750 s Area [01160000-0117FFFF] erased in 0.735 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 22.484 s Reading Simlock info ... Imei net: 35525003587728 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Processing file: rh122_004.300 as MCU [DCT4,DCT4 ALGORITHM] size: 2.38 MB Supported Ids: 2293 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00DAF0B5:2984DA60 Area [01000000-0100FFFF] erased in 0.422 s Area [01010000-0179FFFF] erased in 45.718 s Area [017A0000-017EFFFF] erased in 1.954 s Area [01F00000-01FDFFFF] erased in 0.375 s Flash programming ... Programming completed in 20.313 s File Processed in 1 min 21.391 s Processing file: rh1220_nai04.30md as CNT [DCT4,DCT4 ALGORITHM] size: 208.38 KB Supported Ids: 2293 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00DAF0B5:2984DA60 Area [01750000-0178FFFF] erased in 1.485 s Flash programming ... Programming completed in 1.828 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.031 s File Processed in 19.015 s Processing file: rh122_004.30md as PPM [DCT4,DCT4 ALGORITHM] size: 3.04 MB Supported Ids: 2293 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00DAF0B5:2984DA60 Area [01250000-0125FFFF] erased in 0.407 s Area [01260000-0174FFFF] erased in 29.844 s Flash programming ... Programming completed in 26.546 s File Processed in 1 min 5.281 s Flashing completed in 2 min 45.765 s After Flash Processing ... Reseting Warranty And LifeTimer OK. Reseting Factory Values OK. PhoneType:RH-122 SwVersion: V 04.30 06-07-09 RH-122 (c) Nokia MCU file: rh122_004.300 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00DAF0B5:2984DA60 Area [01000000-0101FFFF] erased in 0.766 s Area [01160000-0117FFFF] erased in 0.781 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 22.671 s Phone Type: RH-122 SW Version: V 04.30 06-07-09 RH-122 (c) Nokia Imei plain: 35525003587728-3 Product Code: 0572834 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MD Language Pack: - not available. Imei net: 35525003587728 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 29.422 s |
The Following User Says Thank You to cikuman.cell For This Useful Post: |
03-23-2010, 09:42 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | Hmmmmmmmmm.. Just ASKING are you USING UFS w/ORIG HWK or not? Br,. Rhyan777 Last edited by Rhyan777; 03-23-2010 at 09:49. |
The Following User Says Thank You to Rhyan777 For This Useful Post: |
03-23-2010, 09:55 | #4 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
ASIC ID: 0x2292, type: 11 This is supported i think but 0x2293 is not supported be warned other wise u would have dead or CS set,, BR | |
03-23-2010, 10:03 | #5 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | [QUOTE=cikuman.cell;5611776] UNLOCK OPTION BY MX KEY IS AVAILABLE Quote:
The Following 2 Users Say Thank You to venuno For This Useful Post: |
1661-2 uk orange cannot unlock with MX Key[UNSUPPORTED MODEL] | NAVEED74 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-06-2010 13:32 |
n97 can unlock by mx-key ? | keongkeong83 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-16-2010 15:24 |
Can we expect new security like n96,95 unlocking with MX-KEY | sairat | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-21-2009 11:09 |
