Old 12-19-2009, 06:07   #1 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
Thanks Meter: 760
Arrow 3110c Flashing Show this error
I m change the cable but problem same.
Help me................
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11446, Date: 25-11-2009
Processing file: rm237__07.21.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.48 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 25B00018E8257E5676D61F1FDDE5812BA968DB7B
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Storing certificate ...OK
Total erase size: 16.37 MB
CMT NOR area [00000000-000006BF] erased in 0.812 s
CMT NOR area [000006C0-0001FFFF] erased in 0.063 s
CMT NOR area [00020000-0007FFFF] erased in 2.625 s
CMT NOR area [00080000-000DFFFF] erased in 0.125 s
CMT NOR area [00100000-001FFFFF] erased in 0.250 s
CMT NOR area [00200000-0031FFFF] erased in 7.469 s
CMT NOR area [00320000-0105FFFF] erased in 39.046 s
CMT NOR area [01060000-01067FFF] erased in 0.062 s
CMT NOR area [01068000-0107FFFF] erased in 0.078 s
Flash programming ...
CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written.
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00900400, Result: 0010
Flashing terminated with error(s) in 2 min 15.610 s
RX Buffer: C7012D0103CD000010000000F172
Old 12-19-2009, 06:16   #2 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
change cable and flashing interface and try again
Old 12-19-2009, 06:17   #3 (permalink)
mr. uem's Avatar
Member: 1035137
Thanks Meter: 72
this mostly from cable problem.
Old 12-19-2009, 08:12   #4 (permalink)
sonu arya's Avatar
Member: 559113
Sonork: 100.1596477
Thanks Meter: 760
I m change 3 cable but problem same.
Old 12-19-2009, 14:04   #5 (permalink)
mr. uem's Avatar
Member: 1035137
Thanks Meter: 72
use 7 pin cable with rx2 pin
Modifiying your cable, change BSI resistor to 5,1 KOhm or 6,8 or gain up to 7,5 kOhm. try it one by one.
and make RX enable manually.
Tested for 3110-c
Old 12-19-2009, 14:09   #6 (permalink)
R@jusat's Avatar
Member: 745721
Sonork: 100.1605292
Thanks Meter: 2,390
its cable probllem change it...............
Old 12-19-2009, 14:11   #7 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
JUST CHECK URE CABLE. THEN TRY WITH FAST FLASH OPTION TICKED.
HOPE URE PROBLEM WILL BE SOLVED.
WBR
sahil2000ind
after flash 5800d-1 show this error msantar MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 10-02-2009 07:33
Whenever i try to flash W200i it show this error amol_sm Universalbox 3 07-04-2009 12:50
Whenever i try to flash W200i it show this error amol_sm Universalbox 0 06-26-2009 16:18
my UB SHOW THIS ERROR HOW TO CLEAR THIS SHIJILFONOTLY Universalbox 6 12-14-2008 13:36
Page generated in 0.23820 seconds with 9 queries
