Old 06-11-2011, 11:45   #1 (permalink)
zeeshan tayyab's Avatar
Member: 828294
Sonork: 100.1615866
Thanks Meter: 124
check this seniors?
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 35417903752056-0
Product Code: 0581455
Battery voltage: 4778 mV, current: 69 mA
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 3541790375+++++
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
is it safe repairable with mxkey(avoid cs after sd repair)????
if tested sombody,,,then post......
Old 06-11-2011, 12:06   #2 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
Thanks Meter: 348
if u make backup rpl in all section then why tension?
do backup rpl in all section.
after repair sd phone goes to security test fail and u know how to repair security test fail.
Old 06-11-2011, 14:58   #3 (permalink)
Member: 828294
Sonork: 100.1615866
Thanks Meter: 124
look my words,,,,if tested sombody,,,then post......so if u have solution then post here all steps with log,,
Old 06-11-2011, 16:53   #4 (permalink)
shybet's Avatar
Member: 492380
Thanks Meter: 184
I have tested, but i didn't keep the log file. So..... sorry i can't help you.
Old 06-11-2011, 19:02   #5 (permalink)
Member: 851708
Sonork: 1000.2brian
Thanks Meter: 15
mx key repair this problem more than a year ago! i tested too on many sets. if you have doubts search in forum, and by the way this is the easiest problem to repair.
The Following User Says Thank You to muthoka For This Useful Post:
Old 06-11-2011, 19:10   #6 (permalink)
KKBaruah's Avatar
Member: 1540165
Sonork: 100.1606502
Thanks Meter: 29
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Brother, Repair SD without any doubt.
Your IMEI plan is valid, So no tenssion.
IF you feel lack of confidence then backup all rpl before operation.
I have no logs to post but succed in many times
Old 06-11-2011, 19:16   #7 (permalink)
Member: 682736
Thanks Meter: 457
Make Rpl Backup.
Do sd repair.
Do Sx4.
Write pm only field 1 and 309.
Thats all...
Old 06-11-2011, 19:35   #8 (permalink)
Member: 851708
Sonork: 1000.2brian
Thanks Meter: 15
if tested sombody,,,then post......[/QUOTE]
boss after sd repair, the set will go into CONTACT SERVICE which tou seem to be afraid of. this is due to security test failed!
to repaier that you neeed to do sx4 and write pm 1 and309.
if you need evidence look at this http://forum.gsmhosting.com/vbb/f550...wered-1154996/
New to all this (about 1 hour) :) Mark UK Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 10-01-2010 09:01
check out my FREE large gsm soft site LaLGsm GSM Mobile Links 0 01-16-2001 04:36
try this for nokia 5.36 BELY Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-28-2000 00:59
READ this IGOR_M!!!!!!!!!!!!! nightxyz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 11-04-2000 04:49
Has someome tested this software Nokia New Series Tool? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 09-20-2000 16:39
Page generated in 0.17641 seconds with 9 queries
