please help me urgently i have a 2set 1650 my problem is see this screen shot Phone Type: RM-305 SW Version: V 5.91 27-03-09 RM-305 (c) NMP Imei plain: 35195703687623-9 Product Code: 0547535 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: MQ Language Pack: - not available. Imei net: 00000000000000 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! i write the pm and rpl but same problem please i need your suggetion please help me thnx |
or if u use hwk initial simlock |
i allready make that but same problem |
i use hwk it show unknown asic 00 |
use hwk and make ui setting your problem will solved |
hi! try downgrade your phone. if not work then do self test and see what area is failed. maybe u need to write pm 120 using pm 120 repair tool or need to write modified pm(without 308) using sx4. after making self test,u can determine what u need to do exactly. |
brother now i make the erase flash and write the good pm. ufs box when i give the unlock unnown asic 00. |
its may be upp problem wbr |
