Old 06-29-2010, 08:07   #1 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
6131 Rm-115 Strange problem
Someone can explain what this mean:
Updating SIMLOCK...OK
missing NPC data in the RPL file, skipped.
Certificate programmed successfully !
Phone Type: RM-115 (Nokia 6131)
SW Version: V 03.70 12-05-06 RM-115 (c) Nokia.
Imei plain: 35629801494748-5
Product Code: 0537699
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
Imei net: 356298014947485
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
Bad Flash IC / Bad CPU ? Flash IC changed twice ... same situation - everything can be rewrited, but SIM-lock is not OK ...
Old 06-29-2010, 09:49   #2 (permalink)
Member: 473926
Thanks Meter: 46
save full backup rpl . repar recover cert.next repair sd go to pm super sd auther load pm full next wright pm next phone unlock phone work ok
Old 06-29-2010, 10:01   #3 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
if your mobileex.log activated try rename first to other.
when get error do update SIMLOCK data,please post your mobileex.log
br,
Old 06-29-2010, 10:03   #4 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
@debeliamark
I am interested to solve your problem by team viewer only, there is a reason.
Thats i hope and sure your phone should be ok.
Br.
Shashank
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.17206 seconds with 9 queries
