Old 04-05-2010, 09:21   #1 (permalink)
Member: 154932
Thanks Meter: 6
nokia e71 RM-357 v301.21.001 UNLOCK?
Sir just wanted to know if this model unlockable im confused if this is SL3?
Old 04-05-2010, 09:52   #2 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 247
i think not possible this version
Old 04-05-2010, 09:54   #3 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
JUST TRY TO UNLOCK WITH WARRANTY UNLOCK OR BY UNLOCK BY CODES AND POST RESULTS.
WBR
sahil2000ind
Old 04-05-2010, 10:09   #4 (permalink)
Member: 154932
Thanks Meter: 6
ok sir, now if ill try to unlock after make all backup let say error occured in warrantry or read codes is there possible result in Simlock corrupted or any other data failed? or this is safe method.
thanks
Old 04-05-2010, 10:11   #5 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
JUST BACKUP ALL IMPORTANT DATA LIKE RPL AND FULL PM
WBR
sahil2000ind
Old 04-05-2010, 10:27   #6 (permalink)
Member: 154932
Thanks Meter: 6
ok sir thanks for all good replies, ill be posting the result bcoz customer got the phone & he will be return maybe tomorrow.. Thanks very much.
Old 06-29-2010, 08:06   #7 (permalink)
danisajee's Avatar
Member: 755480
Sonork: 100.1609798
Thanks Meter: 233
unlock freeeeeeeeeeeeeeee
>> UFS box detected
6/29/2010 12:45:16 PM >> Box firmware version: 208
6/29/2010 12:45:26 PM >> Searching for phone ...
6/29/2010 12:45:28 PM >> Phone found on FBUS interface
6/29/2010 12:45:28 PM >> Reading phone info ...
6/29/2010 12:45:29 PM >> Type: RM-357
6/29/2010 12:45:29 PM >> Version: V 100.71.821.4 06-06-08 RM-357 (c) Nokia
6/29/2010 12:45:29 PM >> IMEI: 352925023518683
6/29/2010 12:45:29 PM >> SP LOCK status:
6/29/2010 12:45:29 PM >> Config Key: 8000000000000000
6/29/2010 12:45:29 PM >> Provider Key: 3027200000000000
6/29/2010 12:45:29 PM >> Block 1: CLOSED Type 5 Data: 302720
6/29/2010 12:45:29 PM >> Counters: 0/3, 0/10
6/29/2010 12:45:29 PM >> Phone is Locked
6/29/2010 12:45:29 PM >> Read Phone Info OK
6/29/2010 12:54:38 PM >> Searching for JAF box ...
6/29/2010 12:54:38 PM >> Searching for UFS box ...
6/29/2010 12:54:38 PM >> UFS box detected
6/29/2010 12:54:42 PM >> Box firmware version: 208
6/29/2010 12:54:52 PM >> Searching for phone ...
6/29/2010 12:54:54 PM >> Phone found on FBUS interface
6/29/2010 12:54:54 PM >> Reading phone info ...
6/29/2010 12:54:55 PM >> Type: RM-357
6/29/2010 12:54:55 PM >> Version: V 100.71.821.4 06-06-08 RM-357 (c) Nokia
6/29/2010 12:54:55 PM >> IMEI: 352925023518683
6/29/2010 12:54:55 PM >> SP LOCK status:
6/29/2010 12:54:55 PM >> Config Key: 8000000000000000
6/29/2010 12:54:55 PM >> Provider Key: 3027200000000000
6/29/2010 12:54:55 PM >> Counters: 0/3, 0/10
6/29/2010 12:54:55 PM >> Phone is Locked
6/29/2010 12:54:55 PM >> Reading PM Field 120 Subfield 0 with length 56 bytes
6/29/2010 12:54:56 PM >> Reading PM Field 308 Subfield 1 with length 8192 bytes
6/29/2010 12:55:10 PM >> Saving to file: RM-357_352925023518683_PM120_PM308_Locked_29-06-2010_125510.bin
6/29/2010 12:55:10 PM >> Saving to file: RM-357_352925023518683_120_and_308_Locked_29-06-2010_125510.pm
6/29/2010 12:55:10 PM >> PM120 and PM308 backup OK
6/29/2010 12:55:27 PM >> Searching for JAF box ...
6/29/2010 12:55:27 PM >> Searching for UFS box ...
6/29/2010 12:55:27 PM >> UFS box detected
6/29/2010 12:55:32 PM >> Box firmware version: 208
6/29/2010 12:55:53 PM >> Searching for phone ...
6/29/2010 12:55:55 PM >> Phone found on FBUS interface
6/29/2010 12:55:55 PM >> Reading phone info ...
6/29/2010 12:55:55 PM >> Type: RM-357
6/29/2010 12:55:56 PM >> Version: V 100.71.821.4 06-06-08 RM-357 (c) Nokia
6/29/2010 12:55:56 PM >> IMEI: 352925023518683
6/29/2010 12:55:56 PM >> SP LOCK status:
6/29/2010 12:55:56 PM >> Config Key: 8000000000000000
6/29/2010 12:55:56 PM >> Provider Key: 3027200000000000
6/29/2010 12:55:56 PM >> Block 1: CLOSED Type 5 Data: 302720
6/29/2010 12:55:56 PM >> Counters: 0/3, 0/10
6/29/2010 12:55:56 PM >> Phone is Locked
6/29/2010 12:55:56 PM >> Read Phone Info OK
6/29/2010 12:55:56 PM >> Searching for phone ...
6/29/2010 12:55:58 PM >> Phone found on FBUS interface
6/29/2010 12:55:58 PM >> Reading phone info ...
6/29/2010 12:55:59 PM >> Type: RM-357
6/29/2010 12:55:59 PM >> Version: V 100.71.821.4 06-06-08 RM-357 (c) Nokia
6/29/2010 12:55:59 PM >> IMEI: 352925023518683
6/29/2010 12:55:59 PM >> SP LOCK status:
6/29/2010 12:55:59 PM >> Config Key: 8000000000000000
6/29/2010 12:55:59 PM >> Provider Key: 3027200000000000
6/29/2010 12:55:59 PM >> Counters: 0/3, 0/10
6/29/2010 12:55:59 PM >> Phone is Locked
6/29/2010 12:55:59 PM >> Reading PM Field 120 Subfield 0 with length 56 bytes
6/29/2010 12:56:00 PM >> Reading PM Field 308 Subfield 1 with length 8192 bytes
6/29/2010 12:56:14 PM >> Saving to file: RM-357_352925023518683_PM120_PM308_Locked_29-06-2010_125614.bin
6/29/2010 12:56:14 PM >> Saving to file: RM-357_352925023518683_120_and_308_Locked_29-06-2010_125614.pm
6/29/2010 12:56:14 PM >> PM120 and PM308 backup OK
6/29/2010 12:56:14 PM >> BB5 FLASH bb5challenge ...
6/29/2010 12:56:22 PM >> ASIC ID: 000000010000022600010006400C192101031103
6/29/2010 12:56:22 PM >> HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
6/29/2010 12:56:22 PM >> ROM ID: 4B9B75103E691FF8
6/29/2010 12:56:22 PM >> CMT Boot Ready
6/29/2010 12:56:27 PM >> Initial PM 308 sent
6/29/2010 12:56:29 PM >> Certificates sent
6/29/2010 12:56:30 PM >> Unlocked PM 308 SL buffer received
6/29/2010 12:56:30 PM >> Unlocked PM 308 field build OK
6/29/2010 12:56:30 PM >> After unlock.
6/29/2010 12:56:44 PM >> Searching for phone ...
6/29/2010 12:56:47 PM >> Phone found on FBUS interface
6/29/2010 12:56:47 PM >> Writting PM Field 120 Subfield 0 with length 56 bytes
6/29/2010 12:56:47 PM >> Writting PM Field 308 Subfield 1 with length 8192 bytes
6/29/2010 12:56:55 PM >> Reset phone ...
6/29/2010 12:57:00 PM >> PM Fields 120 and 308 written OK
6/29/2010 12:57:00 PM >> Waiting for phone to power up ...
6/29/2010 12:57:14 PM >> Searching for phone ...
6/29/2010 12:57:17 PM >> Phone found on FBUS interface
6/29/2010 12:57:17 PM >> Reading phone info ...
6/29/2010 12:57:17 PM >> Type: RM-357
6/29/2010 12:57:17 PM >> Version: V 100.71.821.4 06-06-08 RM-357 (c) Nokia
6/29/2010 12:57:17 PM >> IMEI: 352925023518683
6/29/2010 12:57:18 PM >> SP LOCK status:
6/29/2010 12:57:18 PM >> Config Key: 8000000000000000
6/29/2010 12:57:18 PM >> Provider Key: 0010100000000000
6/29/2010 12:57:18 PM >> Block 1: OPEN Type 5 Data: 00101F
6/29/2010 12:57:18 PM >> Counters: 0/3, 0/10
6/29/2010 12:57:18 PM >> Phone is Unlocked
6/29/2010 12:57:18 PM >> Read Phone Info OK
6/29/2010 12:57:18 PM >> Successfully done.
thanxxxxxxxxx zuliyaa???????
nokia e71 RM-357 I need HELP? (ANSWERED) dune2 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 03-15-2011 15:29
nokia e71 rm-407 is short while unlocking by cyclone plz send me solution 33872 Cyclonebox 5 02-25-2010 19:59
nokia e71 rm-407 is short while unlocking by cyclone plz send me solution 33872 Nokia Base Band 5 ( BB-5 ) 3 02-25-2010 19:37
Nokia E71 RM-357 JonathanDarel Nokia Base Band 5 ( BB-5 ) 3 01-27-2010 10:41
Nokia E71 RM-357 JonathanDarel Nokia Multimedia 0 01-26-2010 01:25
Page generated in 0.22262 seconds with 9 queries
